Solved Problems adding new MBR entries
SimpLe SI
[FONT=&quot]ok, I partitioned my hard drive, installed Linux, added it to the boot loader and everything was fine.
I updated my Linux kernel and rebooted, but because I hadn't configured the Linux LILO bootloader properly i couldn't boot into anything.
Eventually I managed to uninstall LILO and use the HP Vista Recovery on my laptop to use "bootrec.exe /fixmbr" command which proceeded to restore my default Vista MBR.
Since I used that command, my boot loader comes up with Windows Vista and the HP Recovery of which both work. The problem I'm having now is that I cannot add the Linux partition or any other new OS to my boot loader.
Vistabootpro doesn't have the capabilities to add Linux to the MBR, so I used EasyBCD and set my added a Linux entry EXACTLY how it had worked in my previous MBR, yet when I boot up the entry is just not there.
I then proceeded to use cmd in admin mode and use the bcdedit commands to add the information myself.
This is what my current MBR looks like {working Vista, working Recovery but Backtrack not showing up} :
[/FONT]
Code:
Windows Boot Manager
identifier              {bootmgr}
device                  boot
description             Windows Boot Manager
locale                  en-US
inherit                 {globalsettings}
default                 {current}
displayorder            {current}
                        {572bcd60-ffa7-11d9-aae0-0007e994107d}
                        {d9d4316d-6007-11dd-8b43-8943620ecd66}
                        {d9d4316e-6007-11dd-8b43-8943620ecd66}
bootsequence            {d9d43140-6007-11dd-8b43-8943620ecd66}
toolsdisplayorder       {memdiag}
timeout                 4
Windows Boot Loader
identifier              {current}
device                  partition=C:
path                    \WINDOWS\system32\winload.exe
description             Vista
osdevice                partition=C:
systemroot              \WINDOWS
resumeobject            {7048b5a5-5fb4-11dd-8f22-806e6f6e6963}
detecthal               No
usefirmwarepcisettings  No
Windows Boot Loader
identifier              {572bcd60-ffa7-11d9-aae0-0007e994107d}
device                  ramdisk=[boot]\sources\boot.wim,{ramdiskoptions}
path                    \windows\system32\boot\winload.exe
description             HP Vista Recovery
osdevice                ramdisk=[boot]\sources\boot.wim,{ramdiskoptions}
systemroot              \windows
detecthal               Yes
winpe                   Yes
ems                     Yes
Real-mode Boot Sector
identifier              {d9d4316d-6007-11dd-8b43-8943620ecd66}
path                    \NST\nst_grub-7A4ABD950939370EBE03D6A65E90A89E.mbr
description             BT3
identifier              {d9d4316e-6007-11dd-8b43-8943620ecd66}
description             BACKTRACK3
[FONT=&quot]
Thats with a working Vista and working Recovery yet no entry appearing for Backtrack3 even though it is clearly there and installed properly. Ive also tried using bcdedit commands to copy and paste the backtrack entry hoping that it will appear on the boot loader but it just will not.
I can revert back to an older MBR which my Backtrack shows up on the boot loader and will load fine, but then the HP Recovery partition does not boot up.
This is what my old MBR looks like {working Backtrack and Vista but broken HP Recovery} :
[/FONT]
Code:
device                  unknown
locale                  en-US
default                 {current}
                        {d9d4316c-6007-11dd-8b43-8943620ecd66}
                        {d9d43161-6007-11dd-8b43-8943620ecd66}
timeout                 4
Windows Boot Loader
device                  partition=C:
path                    \Windows\system32\winload.exe
description             VISTA
locale                  en-US
inherit                 {bootloadersettings}
systemroot              \Windows
resumeobject            {e8709fb7-fa5f-11db-be4d-e219ece5282e}
nx                      OptOut
Windows Boot Loader
identifier              {d9d4316c-6007-11dd-8b43-8943620ecd66}
description             HP Recovery
systemroot              \Windows
detecthal               Yes
winpe                   Yes
ems                     Yes
identifier              {d9d43161-6007-11dd-8b43-8943620ecd66}
device                  partition=C:
path                    \NST\nst_grub-5F6A92CF71032E4FDDA8EB8D0E76CEC9.mbr
description             BACKTRACK 3
[FONT=&quot]
At the moment I'm staying with the MBR that has the working recovery entry cause its too risky to loose it. Ive tried to add the Linux entry into the bootloader in so many different ways but just cannot get it to work.
Maybe I'm missing something somewhere, but Ive gone over and over this and cannot seem to find whats wrong. Could someone please explain to me why this is so, and how I could possibly fix this.
Thanks
[/FONT]
OK, I saved both of your bootconfigs to separate files, and I noticed something right away:
In the one with the worknig HP, you have a separate identifier string that is completely different from the default Windows boot identifier - but in the one where it dose not work the identifier for both Vista and the HP recovery are the same - hence your problem in not being able to load the HP Recovery console.
Try this:
Code:
device boot
locale en-US
default {current}
timeout 4
Windows Boot Loader
device partition=C:
description Vista
systemroot \WINDOWS
detecthal No
Windows Boot Loader
systemroot \Windows
detecthal Yes
winpe Yes
ems Yes
device partition=C:
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech G15 (gen 2)
    Logitech MX Master (shared)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Radeon HD (Embedded)
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
With EasyBCD, did you try using NeoGrub? It's EasyBCD's own bootloader that searches for /boot/grub/menu.lst (or wherever Lilo may put the file) in the Linux partition and displays the choices. Because Vista behaves a bit weird with me if booted from Grub, I used EasyBCD to give me 2 choices: Vista or Neogrub. Upon choosing Neogrub, then it loads my menu.lst and am able to boot into Linux or OSX.
Hope this helps
    E6750 @ 3.2GHz
    Asus P5K-e/Wifi-AP
    4x1GB Crucial Ballistix DDR2 800
    PNY 8800GT @ 675/1675/950
    Asus Xonar DX
    Samsung SyncMaster 220WM
    500GB WD SATA II
    500GB Seagate SATA II
    700W OCZ GameXStream
    Cooler Master Centurion 5
    Arctic Cooling Freezer 7 Pro
    Logitech G5
    ~3Mb
Booting Vista from GRUB just takes a bit of patience and the *absolutely* correct settings.
However, I had forgotten about NeoGRUB - thanks for pointing that out.
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Which is something I didn't feel like wasting time on :p. While I was able to get Vista to boot, the clock would always be off when it was booted and I wasn't able to put it in Standby or Hibernate after having been in either Linux or OSX. So in the end, i just let NeoGrub handle the other OS's outside Vista's bootloader...
    E6750 @ 3.2GHz
    Asus P5K-e/Wifi-AP
    Asus Xonar DX
    500GB WD SATA II
    Logitech G5
    ~3Mb
thanks guys for your help.
ya, had tried every option with EasyBCD but nothing was working. johngalts post gave me an idea tho. I used my MBR with the working Vista and Recovery and then I added an entry with Vistabootpro using the Legacy bootloader. Then in cmd used bcdedit to change the details and specify my linux and grub settings in that new entry. This seems to have done the trick.
Thanks for your help guys.
Is really appreciated
