Hello Again,
Having another issue booting up, but this one is deffrent from my last one. Had thought it was pretty bad, so i had written everything down so it could help to try and fix this problem hopefully.
This is also a pretty long post, and probably some of it is doubled, didnt mean to cause any spam or anything like that, just trying to help make it easyier for you guys to try and help me.
Also, according to my sister before she had shut down the computer, she was on the internet, and had said it started to open up others non stop so she had turned off the computer, dont know if that could of caused it or not.
had gotten the Following Error on a Blue screen when i had first turned on my PC. After that it had turned off, so i had turned it on to hopefully try to get into safe mode, but couldn't. Instead, i was prompted with the Start Up Repair, I've tried that, after about 2 hours, it had finaly went in for a bit, so i tried a System Restore, it had turned off computer, and was back where i had started.
Computer:
AMD Phenom x3 8400 Tripe-Core processor (2.1Ghz)
4GB DDR2 Memory
320 GB Sata hard Drive
Intergrated NVIDIA GeForce 8200 Graphics
And the OS is Windows Vista Home Premium 64Bit
Just incase it would help any.
Also, Thanks in advance, all help is appriciated.
(On Blue Screen)
Stop: c00021a {Fatal System Error}
The Initial Session process or system process terminated unexpectedly with a Sta.
The system has been shutdown.
Start up repair Diagnosis And Repair Log,
Last Successful Boot time 1-18-09 7:12:55 (GMT)
Number of Repair Attempts: 2
Session Details,
System Disk = \Device\Harddisk0
Windows Directory = C:\Windows
AutoChk Run = 0
Number of Root causes = 1
Test Performed,
Name: System Disk Test
Result: Completed Successfuly. Error Code = OxO
Time taken = 0ms
Test Performed,
Name: Disk Failure Diagnosis
Time Taken 31ms
Test Performed,
Name: Target OS Test
Result: Completed Sucessfuly. Error Code = OxO
Time taken = 140ms
Test Performed,
Name: Volume Content Check
Result: Completed successfuly. Error Code = OxO
Time taken = 188ms
Test Performed,
Name: Boot Manager Diagnosis
Time taken 0ms
Test Performed,
Name: System Boot Log Dianosis
Time taken 0ms
Test Performed,
Name: Event Log Diagnosis
Time taken = 15ms
Root Cause Found,
Unspecified changes to system configuration might have caused the problem.
Repair action: System Restore
Time taken = 191117
Repair Action: System Files Integrity Cheack And Repair
result: Comleted Successfuly. Error Code = OxO
Session Details,
Window Directory = C:\Window
Auto ChkRun = 0
Number of Root Causes = 1
Test Performed,
Name: Check For Updates
Time taken = 31ms
Test performed,
Time taken = 16ms
Test Performed,
Name: Target OS test
Time taken = 187ms
Test Performed,
time taken 187ms
Test performed,
Name: System Boot Log Diagnosis
Time taken = 0ms
Test Performed,
Time taken = 172ms
Test Performed,
Name: Internal State Check
Time taken = 0ms
Test performed,
Name: Boot Status Test
Time taken = 1264ms
Test Performed,
Name: Registry Hives Test
Time taken = 2574ms
Test Performed,
Name: Windows Boot Log Diagnosis
Time taken = 0ms
Test Performed,
Time taken = 1014ms
Test Performed,
Name: Access Control test
Time taken = 17971ms
Test Performed,
Name: File System test (ChkDsk)
Time taken = 0ms
Test performed,
Name: Software Installation log Diagnosis
Time taken = 0ms
Test performed,
Name: FallBack Diagnosis
time taken = 0ms
Root Cause Found,
Unspecified changes to system configuration, might have caused the problem.
Repair Action: System Restore
Time taken = 191117ms
Computer:
4GB DDR2 Memory
(On Blue Screen)
Session Details,
AutoChk Run = 0
Test Performed,
Time taken = 0ms
Test Performed,
Time Taken 31ms
Test Performed,
Time taken = 140ms
Test Performed,
Time taken = 188ms
Test Performed,
Time taken 0ms
Test Performed,
Time taken 0ms
Test Performed,
Time taken = 15ms
Root Cause Found,
Time taken = 191117
Session Details,
Auto ChkRun = 0
Test Performed,
Time taken = 31ms
Test performed,
Time taken = 16ms
Test Performed,
Time taken = 187ms
Test Performed,
time taken 187ms
Test performed,
Time taken = 0ms
Test Performed,
Time taken = 172ms
Test Performed,
Time taken = 0ms
Test performed,
Time taken = 1264ms
Test Performed,
Time taken = 2574ms
Test Performed,
Time taken = 0ms
Test Performed,
Time taken = 1014ms
Test Performed,
Test Performed,
Time taken = 0ms
Test performed,
Time taken = 0ms
Test performed,
time taken = 0ms
Root Cause Found,
- Acer Aspire x3200 ax3200-u3600a
- AMD Phenom x3 8400 Triple-Core Processor
- 4GB DDR2 Memory
- Intergrated NVIDIA GeForce 8200 Graphics
- Intergrated Audio
- 3 GB SATA
