Q6600 @ 2.4Ghz right....
Crispy2007
64 |3!T G33|<
I just D/Led CPU-Z and it came up with this, now what I am wondering is why its saying 266x6 but that equals 1600Mhz and the 6600 is meant to be rated at 2.4Ghz?
    Intel Core 2 Quad Q6600 (G0 Kentsfield) LGA775 (FC-LGA6)
    GIGABYTE GA-EP35C-DS3R (Rev. 2.1)
    Corsair TW3X4G1333C9A 4GB PC-10600 (2x XMS3 2GB)
    ASUS nVIDIA GeForce 8800 GT (G92GT/D8P)
    Creative SoundBlaster Audigy 2 ZS/RealTek ALC885/889A/890
    ChiMei CMV CT-730D 17inch (LCD Monitor)
    1280-1024 60Hertz (Ture Colour 32bit)
    Barracuda 7200.10 SATA 3.0Gb/s 160-GB Hard Drive ST3160815AS (RAID0)
    SUPER FLOWER 500watt Plug in Leads 24pin ATX BLACK MODEL
    Thermaltake Shark (VA7000SWA ATX) Full Tower
    Front 120mm fan (1400 RPM) /Rear 120mm (1400 RPM) blue LED
    Cyber Snipa Stinger Laser Gameing Mouse (400-3200Dpi)
    Labtec Media Desktop Y-SAD65
    Telstra BigPond Elite Liberty Cable 17Mbps/256kbps
Martee
Vista Die-Hard
Check what's your power plan, I guess you currently run the balanced one.
    Gateway P7805u FX
    Intel PM45
    8GB 1066MHz DDR3
    LG 17" WUXGA TFT
    1920x 1200
    WD 2x500GB
    notebook
    BT/BD
archie123
I Tunes hates Me
its fine mate its intels speedstep , it downclocks your multiplier when your cpu isnt under load to save power
as soon as its needed your multipliyer will shoot up to 9x and you'll be back at 2.4
you can turn it off in your bios if you want but unless your an overclocker i wouildnt bother :)
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
error9343
just so you know, even if you disable it in the bios, vista can enable it itself. but you can disable it in vista's "power options"
for dell computers, i think you need to use a "high performance" plan to disable speedstep. that's what it says in the manual.
i currently don't mind it though, so i let speedstep do its thing.
p. s. you should overclock your q6600 to 3ghz
error9343
overclocking + speedstep can work together.
my q6600 is overclocked to 3ghz and speedstep will slow it down sometimes to like 2ghz when i'm not doing anything. but it jumps back up to 3ghz when i do something.
archie123
I Tunes hates Me
if you disable c1e and eist in bios windows cannot manage the cpu power however you set your power optons.
If your overclocking it is recommended , by me and everyone else , that leaving any thing like that on can cause instability in a system , especially if the voltage has been tweaked.
im saying "CAN" you have a small overclock which is obviously fine :)
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
Crispy2007
64 |3!T G33|<
I'm not overclocking iv been through that before already, not with this system.
archie123
I Tunes hates Me
no i didnt say you were , i told you speedstep could be disabled so i thought it worth mentioning that if you overclock its a bad idea to switch it off.
my other posts were to correct somebody else , who's information is a little scewed
just answering your question with as much info as i think you might need :)
sometimes i like to waffle ;)
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
archie123
I Tunes hates Me
oh and ill take that comment as a thank you.............. :p
next time ill leave it to somebody else ;) ;) (jk) :D
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
Crispy2007
64 |3!T G33|<
Ya its all good man, didn't mean anything buy it just wondering why is was saying 1600Mhz that's all, the overclocking side that I have been through was a long road and tuns off blue screens, just don't really want to go through it again but in thinking about it.
archie123
I Tunes hates Me
absolutely no problem mate just having a larf :D
i assume you already know this but theres alot more to overclocking than upping the FSB , if you ever want to try and again and need any help just shout :)
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
archie123
I Tunes hates Me
no problems mate was avin a larf :D
as you probably already know theres alot more to overclocking than upping the FSB , if you decide to delve into the darkside again and want some pointers just shout :D
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
chrisbb
Disable c1e I had the same thing but it is if fine, overclocking is for fools.
Money is tight and the Q6600 will give you plenty of power for 99% of all applications and games.
archie123
I Tunes hates Me
we already been through all this , READ THE THREAD , and i suppose your entitled to yuor own opinion on overclockers
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
error9343
actually i think not overclocking a Q6600 is for fools. it's easy to do and gives you a nice performance boost with no problems if you do it right.
whs
Mine is at 6 times ( at rest ) - even under the high performance power plan.
    Dell
    Q6600
    HP w2207h
    2x250GB HDDs
    1x60GB OCZ SSD
    6 external disks 60 to 640GBs
