Quattro pro
marrypoppins
Power User
You can try OpenOffice, just be sure to download the spreadsheet part of it. I know it helps with other vista works, and words compatabilitie issues. It may also be helpful with your Quattrom, but I cannot be positive that this is the solution.
    Intel(R) Pentium(R) Dual CPU
    Phoenix ROM BIOS PLUS Version 1.10 A11
    2 Gb
    Intel Graphics Media Accelerat
    15.4" Wide Screen XGA+ display with TrueLife™
marrypoppins
Power User
Tell me if it works for you.
    2 Gb
johngalt
Antidisestablishmentarianist
Hi, mickysace, and welcome to the forums.
Vista by itself does nto come with an Office suite pre-installed (OEM *computers* may, but Vista itself does not) and reading on the forums, it is possible that OpenOffice.org's Calc function may not work as well.
From [Solved+Issue] Converting QuattroPro .qpw files (View topic) • OpenOffice.org Community Forum the suggetion is to download a trial version of Quattro Pro from Corel and convert all your files to Excel format, which can then be opened in the OO.o Calc program, or (of course) ini Excel itself.
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Radeon HD (Embedded)
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
