mookiemeister
I have a question about strange defrag behavior when I ran it from the command-line prompt. Yesterday I tried to defrag my HD using both Auslogic's defrag and Microsoft's GUI defrag. Auslogic reported over 30% fragmentation (lots of red blocks from the graphic display) but was not able to defrag it. When I use Microsoft's GUI defrag, it stated that the drive doesm't need to be defrag. Many of the fragmented files reported in Auslogic's defrag program was over 20GB size with strange '{...}' file names. I have no idea what those files are.
I found it strange that it doesn't need to defrag when it reported over 30% fragmentation. Then I decided to use defrag from command line prompt, just to see what happen. I used -w option to defrag large files. After it finished defragmenting my drive, I noticed that my drive's free space increased by 104GB!!! Disk usage stated I was using over 180GB before, and it dropped down to around 80GB after defragging. From my basic understanding of how defrag works, it shouldn't have change the amount of free space on my hard-drive, right? So how did my hard-drive changed from free space of 210GB to 314GB?
- Dell Inspiron 530
- Intel Core 2 Duo CPU E7400 @ 2.8GHz
- 6GB
- Graphics Card(s)
- Intel G33/G31 Express Chipset
- Realtek HD Audio
- Samsung 25" SyncMaster T260HD
- 1920x1200
- 750GB SATA
- PSU
- 300W
- Case
- Dell Inspiron Case
- Cooling
- Fan - Maximum Heat Dissipation 162W
- Dell
- Logitech LX3 Optical Mouse
- 768kbps
- Other Info
- Triple Boot With Windows 7 x64 and Ubuntu Linux 10.04 x64
