pdsnickles
First off, when I go to Create a Restore Point, it always takes the system about 20-40 seconds before it gives me what I want which is C drive checked in the list to create a restore point on. It shows me all my USB hard drives and other partitions, none of which I ever want to choose to create a restore point on.
Is there a way to choose to have only the C drive come up on this list of possible drives for restore points? (I assume this would be quicker, since it would not have to find all those other drives/partitions before showing me the C drive.)
Secondly, since I only have an 83gig partition for C drive with Vista (64-bit Home Premium) and programs using 43 gigs of that; so how much space do I really need for System Restore points? I know there is a page here on this forum somewhere for going into the system via Command and changing the amount of space allotted for System Restore. Should I leave the Default allotted space or should I change it to a smaller amount? (My computer came shipped with a 700+ gig C drive but I shrank it to 83gigs and the rest is for just archiving, with a special partition for ripping and burning and decoding files.)
Third: Where are the System Restore point files or whatever they are stored?
Fourth: Aside from manually creating a Restore Point via System Protection, is there a way I can make it create a Restore Point once a day at a particular time? I think it creates one at startup every day (I'm not sure, but I seem to recall that it does this), but is there a way to tell it, say, to create one every day at 5pm, or something like that in addition to creating one at start up? Or would that require too much disk space alloted to it? (I have a big hard drive, but I'd just as soon not junk it up with an excessive amount of System Restore space.)
Thanks for your feedback.
- DELL XPS 430
- Intel Core™2 Q8200 Quad-Core (4MB L2 cache,2.33GHz,133
- 7200RPM, SATA 3.0Gb/s, 16MB Cache
- 6GB Dual Channel DDR3 SDRAM at 1066MHz - 4 DIMMs
- Graphics Card(s)
- ATI Radeon HD3650 256MB Graphics (Integrated)
- Integrated 7.1 Audio (IDT/Sigmatel 6.10.0.6017)
- Dell -1901FP Flat Panel LCD Color Monitor
- 1024 x 768 32 bit
- 750 gig SATA 7200 C drive
External Seagate 160gig
" Western Book 160 gig
" Hitachi 250 gig
ALL USB except C drive
- Logitech ITough Multimedia
- Microsoft Intellimouse Trackball - (best design ever made!)
- ATT Yahoo Elite DSL 4797kbps down, 624kbps up
