Solved Quick Launch Taskbar Icons Problem
longbelly
My Vista taskbar icons are set to large and the taskbar is not locked - no problems ever. However, I have just installed the latest Adobe Reader update (9.1.3) and several of the taskbar quick launch 'buttons' show and work but the icons themselves do not show - ie the icons are blank. I have tried re-installing the shortcuts, also changing the icons to small but that makes no difference. Not sure where to go from here? Also carried out a full virus scan but nothing found.
    Acer Aspire T180
    AMD Athlon(tm) 64 X2 Dual Core Processor 5000+, 2611MHz
    2048 MB
    NVIDIA GeForce 7300 SE/7200 GS
    Iiyama Prolite H481S 19.1"
    1280 x 1024
    ATAPI DVD W DH16W1P ATA Device 288 GB in 2 partitions
Brink
Staff member
mvp
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
longbelly
Thanks Brink, I think I will try this, although I am just a bit wary of deleting what are in effect system files. What puzzles me though, is that when creating shortcuts for the 'offending' apps on my desktop the icons do show OK. It's just on the Quick Launch taskbar they won't?
    Acer Aspire T180
    2048 MB
    1280 x 1024
Brink
Staff member
mvp
Strange. Are you using shortcuts created directly from the source file or program exe file in Quick Launch instead of a copy of another shortcut?
    Lumia 1520 phone
longbelly
No, but recently I created other toolbars using folders of shortcuts I created in My Documents. This meant I could have a double height taskbar with seperate toolbars to organize my icons. This worked perfectly for a while, until some of the icons vanished. I then went back to using the Quick Launch only and deleted the shorcut folders from Documents. It did look something like this: here
    Acer Aspire T180
    2048 MB
    1280 x 1024
Brink
Staff member
mvp
Creating new shortcuts directly from the source, then moving them into Quick Launch should have them work properly for you.
I'm afraid that I can't see the image since it requires a membership to see it there.
    Lumia 1520 phone
longbelly
Your first paragraph I agree with - but when I create shortcuts direct from the Program .exe files into Quick Launch the shortcuts show but a few are without icons. The offending icons do show on the start menu and desktop though.
Sorry about the link not working - it just showed a two tier taskbar with the grouped toolbars on the bottom tier.
    Acer Aspire T180
    2048 MB
    1280 x 1024
Brink
Staff member
mvp
What programs are these for? We can see if someone with the same programs are seeing the same thing.
    Lumia 1520 phone
longbelly
Three of the programs are Q10, GoodSync and azzCardfile
    Acer Aspire T180
    2048 MB
    1280 x 1024
Brink
Staff member
mvp
My guess is that since they show icons everywhere else, that the exe files just do not include a icon that small in it. If you use small icons at where they normally display, do they still display the icon afterwards?
    Lumia 1520 phone
longbelly
They all did show in quick launch for both large and small, except Q10 which only showed up in large. I have just installed the latest update for GooodSync and the icon shows OK in quick launch.
    Acer Aspire T180
    2048 MB
    1280 x 1024
Brink
Staff member
mvp
    Lumia 1520 phone
longbelly
Probably! So one or another it has been solved, so many thanks for your hand-holding.
    Acer Aspire T180
    2048 MB
    1280 x 1024
Brink
Staff member
mvp
You're most welcome Longbelly. :)
    Lumia 1520 phone
