You should upgrade or use an
alternative browser .
Can I play Race Driver Grid using a Gamepad???
Acer Aspire M1641
Intel Dual Core E2220 2.4GHZ
2GB DDR2
ATI Sapphire Radeon HD 3450 256MB PCI-E 2.0
Philips 192E WideScreen LCD Monitor 18.5`
Seagate ST3250318AS, Western Digital WD3200AAJS-22L7A0
2048kbps downloading, 512kbps downloading
Planning to Upgrade my PC...
Probably you can but you should check Google or try the Gamepad on it just in case.
IDK
IDK
IDK
2 gb
IDK
IDK
IDK
Full screen
IDK
IDK
IDK
IDK
IDK
IDK
Pretty quick
I like playing a LOT of video games. I also like to play with friends, study to learn, and learn new things. :)
PC Geek
yes, but you will probably have to map the keys for it, i use an xbox 360 pad for the same game and it was already mapped to the right keys, as
reptoslicer http://www.vistax64.com/member.php?u=164169 said, i would probably check with codemasters to see if your pad is supported.
Dave
Intel Q6600 @ 2.8GHz
Evga NF78-CK-132-A 3-Way SLI
EVGA 560 GTX SC FTW 1GB
Samsung 7200rpm 250Gb SATA,
Samsung 7200rpm 750Gb SATA,
WD 7200rpm 1TB SCSI SATA.
Antec 900 Gaming Case
Logitech generic keyboard
16Mb Sky bb
The problem is solved. I just used Pinnacle Game Profiler to do that!!! But anyway I think that the game is easier if you play it with a keyboard!!..
Acer Aspire M1641
2GB DDR2
