Random system freezing
Have you tried IE with plugins disabled?
    Windows 7 Pro & 10 Pro
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB & 500 GB
It just froze without any error messages? Again, I didn't look but does this happen if you use IE? Are there any clues in the Event logs.
Where in the event log would you like for me to look?
To all......I really apologize for some of the delayed responses. My oldest dog (never went anywhere without her and my constant shadow at home) had to be put down today. You all have been great hanging in there as this has drug on and I appreciate your patience.
-Mark
    HP Pavilion s3700y (PC)
    AMD Athlon 64 X2 Dual Core 5000+
    Pegatron Acacia
    3GB Micron Technology (PC2-6400)
    NVIDEA GeForce 8400GS
    Realtek High Def Audio
    Compaq WF1907
    1360x768
    Western Digital 320GB
    Slimline
    A little fan
    Logitech M305
    eMachines Enhanced Multimedia
    2703 kbps
I am sorry to hear that. :( Take your time.
    8 gb
    1 TB & 500 GB
Frozen again while in Firefox while clicking on a tab. Time before in firefox using the scroll bar.Now using Safe Mode with Networking. No problems. In the event viewer under System
there was an error at 11:35:01 stating that the shutdown at 11:31.33 was unexpected.....and that's it.
    Pegatron Acacia
    Compaq WF1907
    1360x768
    Slimline
    A little fan
    Logitech M305
    2703 kbps
If you click on an event, it should show the details of the problem.
As I understand it, this all started when you installed the 8400, I would go back to New Egg and try to get a replacement. It's really a crap shoot at this point.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
It really started here: http://www.vistax64.com/1368042-post1.html. And then the PSU went. But the system first froze with the onboard adapter and that went on for a couple of weeks before I got the Newegg card.
I just happed the notice that the onboard adapter drivers were "updated" around the time of the first freeze up. I just download the drivers that initially cam with the computer, just put it in safe Mode and I'm going to uninstall the updated drivers and install the oldies and see what happens.
    Pegatron Acacia
    Compaq WF1907
    1360x768
    Slimline
    A little fan
    Logitech M305
    2703 kbps
Thanks for clearing that up. I remember that thread. Let us know how it turns out.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Same. Froze up even before I launched an application.
    Pegatron Acacia
    Compaq WF1907
    1360x768
    Slimline
    A little fan
    Logitech M305
    2703 kbps
Did you look at the details of the event log, as I mentioned earlier?
I'm at a loss. It really sounds like a cpu or another mobo problem. The fact that it runs ok in safe mode, muddies the waters, in that regard. I think you've already been through a clean boot to remove any questions about software problems.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Going back and forth with the adapters and for the first time with the onboard graphics I had a system freeze while in Safe Mode.
Nothing in the event viewer....absolutely nothing at the times the crashes took place/
    Pegatron Acacia
    Compaq WF1907
    1360x768
    Slimline
    A little fan
    Logitech M305
    2703 kbps
I bet that your card is a lemon. :(
    8 gb
    1 TB & 500 GB
Problem is, it does it without the graphics card installed.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Looks like checkmate.
If someone would answer this question just for my knowledge, I'd appreciate it. I personally think the issue resides with the onboard adapter and I think it is a hardware issue. That said, what is the physical relationship between the onboard video adapter and the PCIe slot, regardless of what card is in it? When the adapter is changed to PCIe in BIOS, then the onboard adapter should be disabled. But isn't that merely a software disabling? From this ignorant chair it just seems that somehow the onboard adapter is physically causing the freezes.
wither 3, richc46 and townsbg........I can't thank you enough for your trying to resolve this issue. I just happen to think that things do break in computers with the high temps in such a small area (HP Slimline) and have a tendency to go probably faster than in a bigger tower. Lesson learned for me. Unless someone has an epiphany that no-one has thought of before, let's call it quits. I've got everything I need on separate drives and as soon as the money becomes available I'll just get a new computer. Seems like the most logical answer at this point. Again, thank you for your time and expertise in trying to get this resolved.
-Mark
    Pegatron Acacia
    Compaq WF1907
    1360x768
    Slimline
    A little fan
    Logitech M305
    2703 kbps
You're welcome.
    8 gb
    1 TB & 500 GB
