Reading Hard Drive to recover data
Chrisalis
I am trying to recover data from a laptop hard drive I have removed from a clients Vista based laptop. The system board appears to be bad, but the hard disk appears to be ok. I am using a SATA to USB adapter to look at the hardrive using another computer (running Windows 7) .
There is an icon with a lock on a couple of the directories. One being the Documents and Settings directory. I can't see files in the directory. I have taken ownership of the directory and I see a subdirectory with my name , as if a subdirectory was created because my computer took ownership , but I don't see other files.
How do I recover the data ?
Thanks
richc46
Welcome
From reading your post, it appears that you are trying to recover the stuff that is on the HD, documents, pics etc.
I think you may want to start with this software. Download and look around. Your stuff may be able to be viewed.
I think going into doucments and settings will lead to a dead end.
Documents and Settings in Vista and Windows 7 - 4sysops
ilikefree
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
Chrisalis
Both of these replies were interesting and helpful. After taking ownership of the directories, I could see the files and copy them. The biggest problem was that there was no obvious user directory. The users data was in a user directory called "test". I suppose the user didn't understand how to set up the accounts.
