Solved Real Techie Help Needed
tconnally
Attempting a clean install Vista 32 full OS (not an upgrade) on the below rig. Previously loaded XP without trouble. Now the following message.
"A required CD/DVD drive device driver is missing. If you have a driver floppy disk, CD, DVD, or a USB flash drive, please insert it now. Note: the Windows installation media is in the CD/DVD drive, you can safely remove it for this step."
I have tried loading XP again and Vista with the same message. Attempting to access the CD unsuccessful.
I have tried disconnecting the LG drive and using the Sony, same error message. LG has no drivers on site stated they are embedded in Vista.
Thanks for any help or recommendation.
PSU- OCZ|OCZ700GXSSLI 700W
MB -ASUS P5N32-SLI SE Deluxe NF4SLI
GPU- ASUS 7950GX2 EN7950GX2/2PHT/1G
CPU- INTEL|CORE 2 X6800 2.93G 775
MEM- 4G|CORSAIR TWIN2X2048-6400
CD\DVD SONY DRX-510UL USB (External)
CD\DVD LG 16x Double-Layer DVD±RW/CD-RW Super MultiDrive LightScribe
KEYBOARD HP wireless
MOUSE HP wireless
Hello tconnally,
Can you go in to your Bios, and see if the Hdd is listed there, take a look and post your results.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    300 Gig Maxtor, (External)
    CoolerMaster 1000
    Logitech G15
    Logitech G5
    20Mbps
The last time i had this, i unplugged the main power lead for ten minutes, cleared the Bios back to default, and said a prayer, i don't know which one worked, but when i tried it, it worked.
I don't think its going to be that easy, but worth a go.
Also take a look at this work around, substitute Flash Drive for Floppy and i think you may have an answer.
http://www.mydigitallife.info/2007/...m-while-installing-vista-on-vmware-serveresx/
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    CoolerMaster 1000
    Logitech G15
    Logitech G5
    20Mbps
