Solved Realtek Audio Manager not opening
JtLK
Thanks to these forums I got the drivers up to date (realtek HD audio driver) and finally the Realtek Audio Manager appeared on the control panel.
I thought my problem was solved but when I click that shortcut it runs RtHDVCpl.exe but the manager doesn't open.
The process is running but no window opens.
Any idea why that's happening?
Or how I can access the darn thing?
I'm afraid I've gone as far as my searching ability can take me
Yard Dog
Hello, are you using an Admin account ? If so, make a new one and try that one , also, are you right clicking it ?
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    Acer E181H ([email protected]) 128MB GeForce 6150SE nForce 430 (
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
JtLK
Only have one user account on my pc, I think it counts as an admin account since I can run things as admin and acess pretty much anything on the pc
Figured it out
Kind of weird :confused:
The process that shortcut runs is the file RtHDVCpl.exe in the Windows folder (clicked open file location in the task manager). And that file was an outdated one, replaced it with the new file from C:\Program Files\Realtek\Audio\HDA and it works now
Now I just have to deal with the crushing despair from finding out the Realtek Audio Manager doesn't see anything but the HDMI output, guess it's more google on that.
Guess I should mark this as solved
Yard Dog
Well, glad you figured this out , strange that your file was outdated tho . As far as the rest of the issue, it is a matter of opening the Sound Manager and peeking around in there. Good luck .
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
JtLK
Quite strange indeed. You'd think the new driver would overwrite it.
As for the rest of my issue it was a matter of going into the setup and setting the onboard audio something to "Enable" instead of "Auto".
My new graphic card was responsible for setting it to HDMI only, with Enable on all other options popped back on the Audio Manager.
My dad figured it out, handy to have a family member with a background in electronics. Guess I really should know more about the setup options though, even if it's outside of civil engineering.
Yard Dog
Ahhh, okay, yeah, that makes sense, thanks for posting that, as not all users have the hardware for that driver , so, if this pops up again, other users will see what was done to sort it out.
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
