Realtek HD audio 5.1 speaker "rear pair" is grayed out
smounche
Hello friends;
i really really need your help in this one.. i just bought LOGITECH x-530 5.1 Speaker system.
when i go to "Realtek HD Audio manager" and choose "5.1 speaker" the "rear pair" is grayed out!
Here is a picture;
Now i know this;
if i change it to 7.1. then the "rear pair" will appear and i will be able to preform the test and hear sound... B-U-T ---> when i will play movies.. (divx, mkx, bluray.. ect'...) i don't hear the people talking.. it's like the wrong sound configuration information goes to the speakers. it will seem the people talking coms from the sub-woofer.. and again really really dim... .+ the rear speakers will work but very low (even when i put it on full volume) .
any idea how to set up correctly the sound ? so even if i am on 7.1. the sound will go to the speakers as 5.1 and send the right information to each speaker?
Thanks !
dale77
I believe this is because in the Realtek HD audio world, the surround speakers are sides, not rears. In a 5.1 config, tick the sides checkbox and plug your black audio cable (rears) into the grey input.
As an alternative to plugging black jack to grey input, you can right click the black input in the "Analog back panel" graphic and "Retask" that input to sides.
    Athlon X2 4850e
    GA-MA78GPM-UD2H
    Corsair 2x 1Gb
    Sapphire ATI 4670
    Onboard Realtek ALC889
    Samsung LA40B530 HDTV
    1920x1080
    WD 10EARS 1Tb
    Antec 430
    Antec Veris Fusion
    2x120mm
    Microsoft 5000
    Microsoft 5000
    2Mbit
smounche
i see.. well i did the second method. and it works. the speakers work as "side" speakers.
my question is now. buy doing this. will my speakers now will work as 5.1 ? i mean when i am watching a movie. that has 5.1 sound. will my speakers act like they should? where each sound goes to the right speaker ?
dale77
Seems to work for me. If you describe the 5.1 speakers as left and right front, center, sub and left and right "surround", the surrounds can be called either "rears" or "sides" depending on who you ask.
    Athlon X2 4850e
    GA-MA78GPM-UD2H
    Corsair 2x 1Gb
    Sapphire ATI 4670
    1920x1080
    WD 10EARS 1Tb
    Antec 430
    Antec Veris Fusion
    2x120mm
    Microsoft 5000
    Microsoft 5000
    2Mbit
smounche
Hello again; i have another issue i will be glad if you can help me with.
all of the cables are connected to the right place... i hope the fallowing picture will explain;
dale77
I don't think you want the "swap center/sub woofer output" checkbox ticked.
Also, depending on exactly what your speakers are, I would think twice about ticking "full range" on the fronts and surrounds.
Enable bass management takes low frequency sound sent to the fronts and surrounds and re-routes it to the sub. You would want to do this if the fronts cannot handle low frequency, and your speaker system does not do this already.
For PC speakers, my pick would be to try nothing "full-range" and enable bass management turned off. Play some music or a movie or something and hear the difference...
    Athlon X2 4850e
    GA-MA78GPM-UD2H
    Corsair 2x 1Gb
    Sapphire ATI 4670
    1920x1080
    WD 10EARS 1Tb
    Antec 430
    Antec Veris Fusion
    2x120mm
    Microsoft 5000
    Microsoft 5000
    2Mbit
