Recover data from erased CD-RW
TBolt
Hi, all. :)
It looks like I accidentally erased a CD-RW that had some personal information backed-up onto it. hehe
1. Is it possible to recover data from an erased CD-RW?
2. If so, is there some software that is recommended for the job?
It would take me quite a while to find some of the information elsewhere; so, I'm just trying to save some time here.
Your input is much appreciated!
    Gateway P-6860fx
    Intel Core2 Duo 1.83GHz
    NVIDIA GeForce 8800M GTS
    Cable
TBolt
I found this on a Google search. May give it a go.
Recover a Quick erased CD RW
If anyone has any personal experience with this situation, would love to hear what you have to say.
Thanks again.
    Gateway P-6860fx
    Cable
lordbob75
Lord of Bobs
Vista Pro
That method sounds like a load of BS to me. I don't think you can get it back from the disk, unless it is in your Recyble bin.
~Lordbob
    ASUS P5QC
    2x2GB
    NVidia GeForce 9500GT 1Gb
    Mobo
    Samsung SyncMaster 206bw
    Samsung SP2514N ATA 250Gb 7200RPM
    Samsung [Model] 1Tb 7200RPM SATA2
    Razer Lachesis
    Razer Tarantula
    not fast enough
TBolt
No, the data is not in my recycle bin -- i wish.
I found some info at the isoBuster site, but I think this is a dead deal. O well.
Thanks! :)
    Gateway P-6860fx
    Cable
AstaLaVista
Lost in Cyberspace
Vista Pro
I used EasyRecovery Pro V6 but it was on my HDD, I do not know if it will work for CDR-W's
    Intel Q9650 w/CM V8 Cooler...
    EVGA GTX260
    Realtek High Def Onboard
    Acer 22" LCD Widescreen
    1680 x 1050
    WD Velociraptor 160GB
    Samsung Sata 750GB
    Maxtor External 160GB
    Thermaltake Speedo Advance
    Air Cooled... See CPU
    Logitech G7
    Logitech G15
    Comcast 6MB Broadband
    Linksys WRT54G router
TBolt
Thanks guys.
From browsing the Net, it looks like most anything that works on the HDD won't work on CD's, but I'll look into it. I'll definitely check out Zip Recovery Toolbox.
Thanks for the leads. :)
    Gateway P-6860fx
    Cable
SIW2
You might also have a look at this - Unstoppable Copier
Roadkil.Net
SIW2
    Intel E8400
    ASRock1333-GLAN R2.0
    2gb DDR2 800
    nvidia 9500GT 1gb
