Recovering WPA2 password
Posts
3
I have tried getting my WPA2 password from my router but can't get into the page using "admin" "password" etc or any other combination. This laptop has it stored somewhere in vista because when I turn it on it automatically connects to my network. My other computers have lost the stored code and I want to get it from wherever it is stored here in Vista so I can input it back into my other machines. Can anyone help me?
Thanks
Jeff
dreemwarrior
SI'HASAP
Austin Tx
Posts
153
Thanks
Jeff
Hi jeffneedshelp
I've been searching for a solution for you. In the mean time, you can try
Network Password Recovery - Recover Windows XP/Vista network passwords (Credentials file), a PW recovery utility.
Please be advised you should always scan any downloads and monitor them with AV software. This software does report false positive spyware.
    Core i7 860 Lynnfield
    Asus P7P55D Deluxe
    Corsair XMS 3 PC 1600Mhz
    ATI Radeon HD 5770
    LG 2350 Flatron HD
    1920x1080
    Barracuda 1Tb
    650w Corsair
    Antec 900
    CoolerMaster Hyper212
    5 button w/speed control
    yeah,somewhere...
    cable modem
    Running a very stable 3.6Ghz @ 8-8-8-24 1.65v
Posts
3
Thanks dw- I tried that and got a pw but couldn't get it to work so finally I just reset the router and started fresh with a new WPA2 key which is probably good anyway since my old key seemed to be a WEP key even though I thought it was a WPA2.
dreemwarrior
SI'HASAP
Austin Tx
Posts
153
Sometimes thats the best way to go at any rate. WPA's,like any other PW, should be changed from time to time. :)
Wish I could have been of more assistance.
    Asus P7P55D Deluxe
    ATI Radeon HD 5770
    LG 2350 Flatron HD
    1920x1080
    Barracuda 1Tb
    650w Corsair
    Antec 900
    yeah,somewhere...
    cable modem
Darr247
Posts
1
If this happens again, connect to the wireless network with the computer that knows the password, then do Start/Orb -> Run/Search, ncpa.cpl [Enter]
In the Network Connections window that opens, click on the Wireless Network Connection. Then click View status of this connection (on the 'Organize' toolbar).
In the Wireless Network Connection Status window that opens, click the Wireless Properties button.
In the [network name] Wireless Network Properties page that opens, click the 'link' that says Copy this network profile to a USB flash drive. You'll be prompted to insert a USB key (even if you already plugged it in), but about any removable media the application will use are listed... select one and click Next.
Now when you insert that USB stick/SD card/whatever into the windows computer that doesn't know the password, one of the options offered in the Autoplay window, which appears after the medium is scanned, should be "Connect to a wireless network" - if you choose that option, the wireless network settings should be replicated to the new/different computer.
The final window that appears when copying the settings to the USB drive says it should work with any win7, vista or XP computer, but in my experience the WPA2 password setting is NOT transferred to XP machines correctly... still, that method should work between vista<->vista, 7<->7 and vista<->7 with no problem.
