Recovery Drive D is low on disk space, won't allow me to download programs
bellzisu
Recovery Drive d is low on disk space... It for some reason won't let me download programs or files. I tried to put Itunes on the computer and it won't let me. It has a pop up saying Not enough room on RECOVERY
Can anyone help???
richc46
richc46
No
I gave you directions on how to turn off. See my post. Turn if off, that deletes all points, but you may need one. Turn it back on, make a point and then see if you can install.
You turn on by doing the same in reverse.
The tutorial in the above post tells you how to turn on.
richc46
Wish you luck
richc46
It did work, right?
