Recycle Bin Menu
ByLine
How to Replace "Delete" in the Recycle Bin Context Menu in Vista
Synopsis
This will show you how to replace Delete in the Recycle Bin Context Menu with Disk Cleanup, Search, or Clear System Temps
This will show you how to replace Delete in the Recycle Bin context menu with Disk Cleanup, Search, or Clear System Temps.
EXAMPLE: Recylce Bin Context Menu with Delete
EXAMPLE: Context Menu after Delete is Replaced with One of These Options
NOTE: You do not need to restore Delete to switch between the items below to replace Delete with. They will automatically replace each other. You will only need to restore Delete if you want Delete back instead of the items.
1. To Replace Delete with Disk Cleanup
Replace with Disk Cleanup.reg
download
B) Go to step 5.​
2. To Replace Delete with Search
Replace with Search.reg
download
B) Go to step 5.​
3. To Replace Delete with Clear System Temps
NOTE: This clears the %UserProfile%\AppData\Local\Temp and %SystemRoot%\Temp temporary files in Vista.
A) Click on the Download button below to download the file below​
Replace with Clear System Temps.reg
download
B) Go to step 5.​
4. To Restore the Default Delete
Restore Delete.reg
download
5. Click on Save, and save the .reg file to the Desktop.​
6. Right click on the downloaded .reg file and click Merge.​
7. Click on Run, Continue (UAC), Yes, and then OK when prompted.​
8. When done, you can delete the downloaded .reg file if you like.​
  • Replace with Clear System Temps.reg
  • Replace with Search.reg
  • Restore Delete.reg
  • Replace with Disk Cleanup.reg
Brink
Staff member
mvp
Hi Paulmallory,
Welcome to the forum. :party:
What specifically did not work for you? This way I can investigate it for you to see what may have happened.
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
paulmallory
The recycle bin icon on my desktop still does not change to full when items are placed into it. This all started when I accidentally deleted the recycle bin icon from my desktop. I got it back on the desktop, but it won't change to full.
Brink
Staff member
mvp
    Lumia 1520 phone
bam4846
This did not work for me on my Vista Home Premium 32 bit machine.
It added the Disk Cleanup path to the recycle bin but it did not remove the Delete option. Removing the Delete option is really all I want to do.
Brink
Staff member
mvp
Hi bam4846,
Welcome to Vista x64 Forums. :party:
Strange these were tested on both the 32 bit and 64 bit versions of Vista. Did any of the other ones replace Delete for you?
    Lumia 1520 phone
bam4846
Only tried the one since it was moderately useful to me.
I really would just like the delete option removed with nothing else added. Unless I could replace it with a "winning lottery numbers generator" option. That would come in handy. Anything else just makes a large pain-in-the-ass into a small pain-in-the-ass.
Thank you for your reply.
Bare Foot Kid
R.I.P. August 13th 2014
Hi Brink!
I was just wondering if other things can be removed from the
recycle bin menu?
Thanks for you'r reply.
Later, Ted :shock:
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
Brink
Staff member
mvp
Ted, I'm sure there may be a way somehow. What are you intereseted in removing? I'll take a poke around the registry to see if I can find it.
    Lumia 1520 phone
Brink
Staff member
mvp
bam4846,
Sorry, you can only replace it to remove Delete. Search is not a bad alternative.
    Lumia 1520 phone
Bare Foot Kid
Hi Shawn, Thanks for you'r offer. But it's not worth the trouble !!!
Thanks anyway, Ted :shock:
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
davehc
Vista Pro
Just run this reg file (trust me!) the del will be gone.
  • recycle.zip
Brink
Staff member
mvp
Hi Dave,
Yes it will. It's the same as the replace with Search option. ;)
    Lumia 1520 phone
ggbib
All 4 of the .reg's work here. Is there a way to get all 3 tweaks on the menu at once?
J
    home build
    AMD Phenom II X4 955
    MSI K9N2 SLI platinum
    4gb
    2 Nvidia 9800gt's SLI'd with 660 core clocks, 512mb ddr3 ea.
    runs thru home stereo, 7.1 channel
    22" Samsung
    c: 320gb maxtor, d: 1tb wd, e: 500gb maxtor, g: 500gb hitachi, 2 external 500gb wd's in enclosures
    750w Corsair
    Zalman
Brink
Staff member
mvp
    Lumia 1520 phone
Brink
Staff member
mvp
Your welcome Philosos. Thank you for the feedback.
    Lumia 1520 phone
ckc
After I deleted my recycle bin about a 100 times I found your solution and replaced delete with Clear system temps.and repaired the icon.This is the best thing ever,what a simple fix for big pain in the butt. Vista Home Premium 32 bit and it works just fine,thanks
Brink
Staff member
mvp
Your welcome CKC, and welcome to Vista Forums. :party:
I'm glad to hear that it was able to help you.
    Lumia 1520 phone
