Reformated my hard drive, the computer will not load games disks, in cdrom.
erick1
I have two, 1 is a dvd rom, the other is a cd rom, the dvd says that ANYthing that I put in must be formated (dvd, game, drivers... you name it), the cdrom says nothing when I put a disk in.
what can I do to fix this?
Hello erick1,
Do you have any DVD/CD burning software, such as Roxio, or Macrium, or any other type of software connected with the DVD/CD drive ?.
If you do, disable it, or remove it, it is more than likely that it is something like that, interfering with your DVD/CD drive.
Good luck and post your results.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    300 Gig Maxtor, (External)
    CoolerMaster 1000
    Logitech G15
    Logitech G5
    20Mbps
Stoneys, no, the computer is freshly refomrated, nothing on it at all, my device manager says that everything is working perfectly, but says any disk I put in, and I mean any, is not a format that window recognizes.
any other tips?
it has to be the same format, It is warcraft, then I put in sims3, then I put in a music CD, then I put in a few DVDs, it says that none of them are a format that windows recognizes, when they ALL worked before the reformat, the drivers are all up to date.
