Reformatting Problem
1
Hello,
I have a problem installing a brand new vista 32bit onto my gateway comp. I have formated my partitions into one. Here's what happens, I load my gateway operating disk into my cd drive then I boot from the disk. It loads up and then I click on install vista icon. I then reformat the partition then I delete the partition then I create a new partition with max memory on it. I then hit next. After I hit next the installation begins. About 60% into the installation i get this message:
Windows cannot install required files. Network problems maybe preventing Windows from acessing the file. Make sure the compter is connected to the network and restart installation. Error code 0x80070005.
Plz help! thanks!:D
Alex95
28
Location
Rome
Try without clicking "Get Latest Updates"
    HP 6730s
    Intel Core 2 Duo T5670 @ 1.80 ghz 4 mb L2 Cache
    2 GB Ram DDR2
    Intel 4500MHD 128 MB own ram, 796 shared
    HD Audio Output
    1280x800 max on the laptop (1920x1080 on Full Hd Screen :) )
    150 Gb Toshiba 7200 rpm
    7 Mega download, 1 mega upload
