Solved Reformatting Query
I just purchased an Acer Aspire L3600 with two 300gb dir. [duo cpu E4700 @ 2.6 ghz] which came loaded with Vista Home Premium [32bit] and I'd like to load XP Home.
Can anyone help me?
Thank you
Tanmei
dinesh
Vista Expert
Can anyone help me?
Thank you
Tanmei
Do you want to dual boot it or completely remove vista and load xp on it?
    Compaq
    intel 965 chipset family
    2 GB DDR 2 SD RAM @ 667 MHz
    On board upto 358 MB RAM
    15"
    160 GB WDC
Can anyone help me?
Thank you
Tanmei
Thanks for your prompt reply - much appreciated.
I'd like to remove it completely and load XP
Brink
Staff member
mvp
Hello Tanmei,
In that case, check to make sure that you have XP drivers available for all of your devices and download them to have them handy to install later.
If it is a retail XP version, then you can just boot from the XP installation DVD and format your hard drive and finish installing XP on your computer. :)
Be sure to backup any file that you do not want to lose first though.
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
Hi Shawn,
Thanks for your reply.
In preparation for reformatting my PC I went to the MS website and downloaded all the XP SP2 drivers and at the Acer website I downloaded all the Aspire L3600-related XP drivers, including the bootable disc from the ISO. However, a few minutes into the reformatting process a message came up saying, "BootMGR missing," and stopped ...
I tried inserting the bootable disc I made from the ISO and the various drivers discs, too, but nothing happened!!
Any suggestions?
Brink
Staff member
mvp
Tanmei,
Is this an upgrade version of XP? If so, then you will need to have a older Windows installed on there first to upgrade to. If you want to do an installation from a formatted hard disk, it will only install from a Full an OEM version XP disc.
If not, then you may have a bad DVD image. :(
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
Hi folks,
Thanks for the assistance -
I managed to overcome the issue by taking the pc into the local shop down the street where the tech finished deleting Vista.
I took the pc home and loaded XP Home without a problem and it's smoking :cool:
Problems solved :party:
Brink
Staff member
mvp
#8
Tanmei,
I'm happy to hear that you got it sorted out. :)
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
