Refurbished PCs
VFN
What do you guys know about refurbished PCs. Are they a good value, a good buy?
Thanks.
    Vista Home Premium x64
    Dell Inspiron 546
    Sempron LE-1300
    2GB DDR SDRAM 800MHZ-2X1GB DIM M
    Integrated ATI Radeon HD3200
    VIA High Definition Audio
    Samsung 32" HDTV
    1366 x 768
    320GB NCQ Serial ATA (7200 RPM) w/ 16MB DataBurst Cache
townsbg
~~тσωηsвg~~
My mom got one and is happy with it. You have to watch what you get and consider price with age and signs of use such as blemishes.
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
richc46
With a lappy, be very very careful and check out the hinge that attaches the cover to the keyboard. Make sure that there is no cracking sounds, stiffness or other problems when opened.
VFN
Thanks. I did some reading, heard from others and the consensus seems to be that they're a good deal if the refurbisher is the original producer or an otherwise reliable entity and has a decent warranty.
    Dell Inspiron 546
    Sempron LE-1300
    Samsung 32" HDTV
    1366 x 768
Jody Thornton
Power User
My HP xw8200 is now the fifth refurbished workstation from a small PC shop. I have been very lucky going this route. I used to assemble my own, but the last one was a clone case housing an AM K6-2 550 MHz with 392 MB of PC-133 RAM. I used it happily with Windows 2000 Professional. So it's been awhile. :)
    Windows 8 Pro x64
    HP xw8600 Workstation
    Two Intel Xeon Core2 Quad 3.2 GHz Processors
    Proprietary
    16 GB DDR2 800 MHz
    nVidia Quadro FX 3800 PCI-E
    Realtek HD Audio
    Samsung SyncMaster 213T 21" 4x3 Flat Screen
    1600x1200
    Two Seagate Cheetah 300 GB SAS Disks
    Proprietary
    HP xw8600 Workstation Case
    Two CPU Fans and One Larger Cooling Fan
    Microsoft USB Optical Mouse
    PS/2 Keyboard
    7 mbps
    Storage Interface: Two LSI 3000 SAS Adapters
    Browser: Firefox ESR 91
Cammygirl192
Cammy White FTW
I haven't got experience but you have to make sure that there's nothing wrong with it, if it's from eBay you might want to check it all works before you buy it or you'll be wasting your money.
    Packard Bell imedia s3210
    AMD Athlon(tm) 7450 Dual Core Processor (2.40GHz)
    2.00GB
    NVIDIA GeForce 8200
townsbg
~~тσωηsвg~~
Just a thought but I'm not sure how you will check the computer before buying if you are buying through ebay unless the seller is willing to meet. What you can do is look for auctions that have a return policy (not all do but that would be a plus) and look at the seller's rating as well as reviews from previous buyers. Personally I wouldn't buy a computer from ebay unless it is a specific model I happen to need that I can't find anywhere else.
    8 gb
    1 TB x2
    Dell Poweredge T140
    1 TB & 360 GB x2
ilikefree
Thinkpad I'm now using I got from Trade Me a New Zealand site like Ebay
I needed to replace the battery and it came with no hard drive so I fitted a SSD
It did come with the docking station
I paid $100 NZD
It was not refurbished, just a second hand laptop
Installed Vista from a DVD and have had no problems with it
Would I go this route again, Yes
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
ilikefree
It's ok to buy from official but don't buy it from personal.
I found no problem with personal. It was what was advertised and came well packed.
    LENOVO 64734VM
    15 inch
    External Speakers
