Solved Regedit - Enable or Disable?
puzzeld
Banned
Hi not sure about this? is it good idea to configure Regedit to Enable in the Local Group Policy Editor?
I checked it and it says it's not configured it's not enabled either?
Do i just leave it ALONE or configure it?
:geek:
  • Name
    Karlton
    Toshiba Satellite M300/300 IntelCore 2DuoT8100
    Processor Intel(R) Core(TM)2 Duo CPU T8100 @ 2.10GHz, 2
    HDAUDIO Soft Data Fax Modem with SmartCP
    2GB (Max. up to 4GB)
    ATi Mobility Radeon HD 3470 (256MB discrete video)
    ATI Function Driver for High Definition Audio - ATI AA0
    14.1 inch Wide Screen WXGA LCD
    Resolution 1280 x 800 x 60 hertz
    320GB SATA Hard disk
    Drive C Local Fixed Disk
    S3A6586D005
    NTFS File System
    Drive D CD Rom Disk
    75W (19V x 3.95A) 100-240V AC Adapter.
    Weight 2.166kg (may vary with spec)
    Fan/Air
    Microsoft USB Notebook Optical Mouse 3000 Intellipoint+T/Pad
    Integrated 10/100/1000 Network Card Integrated Wireless LAN
    Occupation
    I Am What I Am
    Toshiba Bluetooth™ V2.1 + EDR (Enhanced Data Rate)
    ATI Mobility Radeon HD 3470 (256MB discrete video
    memory and upto 1023MB shared video memory using
    HyperMemory technology with 2GB system RAM)
    Wireless Networking Integrated Intel 802.11 (a/g/n)
    Premium Harman/Kardon® speakers
    Country Flag
    australia
    State/Region Flag
    au west australia
Brink
Staff member
mvp
  • Show second system?
    Yes
    Operating System
    3 x 27" Asus VE278Q
    1920x1080
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
    Operating System
    Country Flag
    usa
    State/Region Flag
    us oklahoma
    Gender
    Male
    Yes
    Operating System
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
    Operating System
    Country Flag
    usa
    State/Region Flag
    us oklahoma
    Gender
    Male
puzzeld
Banned
Hello Puzzeld,
I would recommend to leave it set as Not Configured. Setting it to Enabled in GPEDIT will disable access to the registry for all users.
http://www.vistax64.com/tutorials/116415-regedit-enable-disable.html
Okay thanks i will leave it as is. :geek:
So how does the registry update?
I used CCleaner to clean my registry it found only minor stuff but i think maybe some unused stuff should stayed,the problem is the backup i saved in documents has disappeared for some reason.
Also there was some active X stuff.
A few weeks ago when i started my notebook Microsoft or my ISP provider>>not sure now>>said it would update drivers.
Thats when i noticed some my Files in my Documents where missing real weird like my CCleaner backup disappeared in Documents.
Think i need to dump that CCleaner yes/no question.
I think using it in the Registry was a stupid thing to do :o
I found 2 files from backup an i think CCleaner made a big mistake here i still have it if you like to look for me.
:eek:
  • Name
    Karlton
    S3A6586D005
    NTFS File System
    Drive D CD Rom Disk
    Fan/Air
    Occupation
    I Am What I Am
    Country Flag
    australia
    State/Region Flag
    au west australia
Brink
Staff member
mvp
CCleaner is a great and handy program to use, but I would recommend to never use that registry cleaner feature or any other registry cleaner program. Allowing a registry cleaner to delete something that it should not have could cause you to have to end up reinstalling Vista to fix it. It's just not worth it. Especially if one is not sure of what should be and should not be allowed to be deleted in the registry.
You might consider doing a system restore using a restore point dated before you ran the registry cleaner feature to see if it may be able to undo this for you.
    Yes
    Operating System
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
    Operating System
    Country Flag
    usa
    State/Region Flag
    us oklahoma
    Gender
    Male
    Yes
    Operating System
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
    Operating System
    Country Flag
    usa
    State/Region Flag
    us oklahoma
    Gender
    Male
puzzeld
Banned
Oh okay thanks yes i wont do it again :o
CCleaner cleans other files up great.
Yes i done system restore>>so that fixes registry?
Brink is that revo>>safe to use? :eek:
  • Name
    Karlton
    S3A6586D005
    NTFS File System
    Drive D CD Rom Disk
    Fan/Air
    Occupation
    I Am What I Am
    Country Flag
    australia
    State/Region Flag
    au west australia
richc46
Yes, revo is safe to use, but like all software only when used properly. It has been recommended, by many members to help others. I have suggested its use and used it myself with excellent results. You may want to make a
system restore point before its acual use, in the event of problems, which can occur with any install or uninstall. For instructions see post by Brink.
In answer to your other questions, yes SR will fix registry errors. SR should be considered as an important part of your OS. If restore points are kept up to date in addition to the manual ones which should be made before any change to the OS (points supposedly are made by defualt, but I make one manually, anyway) you will be able to return to a point in time before the problem ocurred.
Since I have helped you in other threads, you seem to be making extensive use of our Forum. All the members are glad that you realize that we provide a valuable service and are using it to the fullest extent. I will gladly provide you with a copy of our Tut index, which you can used to supplement your knowledge of Vista.
http://www.vistax64.com/tutorials/139940-tutorial-index.html?filter[11]=General Tips
Take Care.
  • Name
    Richard
    Country Flag
    usa
    State/Region Flag
    us connecticut
puzzeld
Banned
Take Care.
HI~~~hey thanks for that information+tutorials is awesome all the Vista info you need.
Yes heard no complaints about revo seems to do more than CCleaner.
  • Name
    Karlton
    S3A6586D005
    NTFS File System
    Drive D CD Rom Disk
    Fan/Air
    Occupation
    I Am What I Am
    Country Flag
    australia
    State/Region Flag
    au west australia
richc46
Glad that you are happy with the information. But, just wait, if you liked the revo and cclean information, wait unitl you really start to get into those tuts. It is my honest opinion that those tuts represent the best information, on the market, today, including those that come with a price.
Thank you so much for your kind words and rep.
  • Name
    Richard
    Country Flag
    usa
    State/Region Flag
    us connecticut
