register msstdfmt.dll on Vista 64
TerryWallis
I'd be grateful if someone can tell me how to register msstdfmt.dll on my Vista 64 bit system ?
I cannot get advice that works from the web!
I have put this msstdfmt.dll in both System32 & Syswow64............is this right ?
Thanks,
TerryWallis
townsbg
~~тσωηsвg~~
    Windows 7 Pro x64
    Mid 2010 iMac
    Quad core 3.2 Ghz Intel I3
    8 gb
    ATI Radeon HD 5670 512 mb ram
    1920x1080 and 1440x900
    1 TB
    Windows 2008 R2 Enterprise
    Compaq Presario SR5350F
    Pentium 2.0 gHZ Dual core E2160
    2 gb
    1440 x 900
    300 GB
TerryWallis
Yes but it doesn't tell me how to use command prompt that I can see.......what do I enter to register the 2 files in System32 & Syswow64, etc ?
townsbg
~~тσωηsвg~~
After the DLL file has been pasted to the right folder on your computer, you must register the DLL file with Windows Registry. You can do this using the regsvr32 command in a Command Prompt with administrative privileges; just use whichever command applies to your version of Windows:
32-bit: regsvr32 c:\windows\system32\msstdfmt.dll
64-bit: regsvr32 c:\windows\syswow64\msstdfmt.dll
From the start menu right click on command prompt and select run as administrator. Just register the 64-bit.
    Windows 7 Pro x64
    Mid 2010 iMac
    8 gb
    1 TB
    2 gb
    1440 x 900
    300 GB
TerryWallis
Yes ....I have used command prompt many times before. My question was, what do I write to get it to register the files ?
and I see your link has 64-bit: regsvr32 c:\windows\syswow64\msstdfmt.dll so I'll try that.
Thanks
townsbg
~~тσωηsвg~~
I'm glad to hear it.
    Windows 7 Pro x64
    Mid 2010 iMac
    8 gb
    1 TB
    2 gb
    1440 x 900
    300 GB
wither 3
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
