Registry Cleaners
Chiefjim
12
I read quite often about the possibility of "registry cleaners" messing things up on Vista. Is it recommended not to use a registry cleaner at all? Are there good/bad ones? My computer is almost brand new so I don't believe I have any problems. I used a registry cleaner on my old XP computer.....it found lots of problems.....fixed them and the machine ran better than ever!
kavita
CCNA
Vista Pro
276
Location
India
    Intel Dual Core 3 GHz
    3 GB DDR 2 667 Mhz
    ATI X1550 256 MB
    Samsung 19"
    80 GB IDE Samsung.
    iBall
    iBall
    2mbps
143
Location
Florida
Hi Chiefjim,
Speaking from personal experience, I recommend NOT using a Reg Cleaner. However if in the end you decide to anyway, I suggest the following.
1. Be sure the one you choose makes a registry backup of the files it will remove. Note: this backup has nothing to do with the Windows Restore Point.
2. Do not allow it to 'clean' windows system files.
Just a suggestion for you, there is a product (FREE) that is very popular (I use) called CCleaner very user friendly, and hasn't let me down yet, and updates are about every month or so. CCleaner - Update
Best of luck,
Jakeman97
    H1 HUMMER
    Phenom II X6 1055T
    GA-890FXA-UD5 AM3
    G.SKILL 4GB F3-10666CL8D-4GBHK
    XFX Radeon HD 5750
    On Board (works for me).
    Acer X223W
    2 Seagate Barracuda 7200.12 750GB \\ 2 Seagate Barracuda 500GB SATA3 7200.12
    Corsair HX 1000W
    Cooler Master 690II Advanced
    Cooler Master V8
    Microsoft
    Microsoft CA9-00001 Black 103 Normal Keys 3 Function Keys PS
    Fast DSL
    A work in progress and changing all the time.
AstaLaVista
Lost in Cyberspace
Vista Pro
1,234
Location
Miami, Florida. USA
I use CCleaner regularly and I have had no problems yet... I guess the key is not to touch the "Windows System Files" as explained by Jakeman97.
I often used it more to get rid of any instances of an application (or driver) I just uninstalled.
    Intel Q9650 w/CM V8 Cooler...
    EVGA GTX260
    Realtek High Def Onboard
    Acer 22" LCD Widescreen
    1680 x 1050
    WD Velociraptor 160GB
    Samsung Sata 750GB
    Maxtor External 160GB
    Thermaltake Speedo Advance
    Air Cooled... See CPU
    Logitech G7
    Logitech G15
    Comcast 6MB Broadband
    Linksys WRT54G router
229
Location
Redmond, Washington, USA
AstaLaVista and Jakeman97 are on the right track here. A well-informed use of something like CCleaner or even manual cleaning can be beneficial to remove bits and pieces, but the second you get into the Windows System Files, you risk the chance of doing some damage.
Cheers,
    Dell XPS M1330
    Intel Core 2 Duo
    3GB
archie123
I Tunes hates Me
1,831
Location
UK
personally i cant see a registry cleaner making any differance
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
187
Location
Minnesota
I use CCleaner and have never had a problem but I do back them up and after awhile I Don't see any problems I get rid of them. Also make sure you know what your deleting.
There is now option for Windows System Files am I missing something?
    Dell Inspiron 530
    Intel Core 2 quad Q6600 2.40GHz
    OFM586
    3.5GB DDR2 at 667MHz
    19inch dell HD flatscreen
    1280x768 60hz
    7mb
143
Location
Florida
#8
Hi venom762,
Your not missing anything. That was just a caution to the OP; that no matter what product he chooses to use, "Don't let it clean Windows System Files".
CCleaner does have a 'System Section', and an 'Advanced Section'. You are absolutely correct when you stated, "Also make sure you know what your deleting".
Jakeman97
    H1 HUMMER
    Phenom II X6 1055T
    GA-890FXA-UD5 AM3
    XFX Radeon HD 5750
    Acer X223W
    Corsair HX 1000W
    Cooler Master V8
    Microsoft
    Fast DSL
187
Location
Minnesota
#9
Great, thank you.
    Dell Inspiron 530
    OFM586
    1280x768 60hz
    7mb
