I've spent the last hour or so scouring Google for a simple program that will let me see every change/addition the installation of a program makes to the registry during installation. I tried to use Sandboxie, but it kept giving me weird errors (I know Sandboxie works fine, I've used it on plenty of other programs before) If that program could also show me every directory it adds/modifies on my computer that would be awesome as well, but right now I mainly want to see what it's putting in the registry. If anyone has any such programs in mind I'd love them since apparently Google can't find any for me.
I did see some stuff about one called RegMod, but all the links I found were broken, and it seems like a really old program anyway.
Thanks
Thanks
- Dell Inspiron 1545
- Intel Core 2 Duo T6400 @ 2.00 GHz
- DELL - 27d90219 Phoenix ROM BIOS PLUS Version 1.10 A05
- 4 GB
- Graphics Card(s)
- Mobile Intel(R) 4 Series Express Chipset Family
- IDT High Definition Audio CODEC
- Generic PnP Monitor (DPMS), 15.3" (34cm x 19cm)
- 1366x768
- Internal 320 GB
Portable 320 GB used for separate storage of media, plugged into USB port as needed.
- Cooling
- Single built in fan
- Built in
- Touchpad, + Logitech wireless mouse (USB)
- ~150 kilobytes/sec DL
- Other Info
- Usually have low HD free space left (<10 GB), often left on overnight. I really push its capabilities.
