Registry Repair/ Cleaner for Vista?
dagzag
Does Vista need a registry cleaner/repair program? Is Vista better than XP at keeping the registry clean? If not, is there a program you would recommend?
Thanks
Hello dagzag,
I like using the free Wise Registry Cleaner. It does a great job of keeping my registry clean.
WiseCleaner.com - Downloads
For a great free registry defragger, I like using Auslogics Registry Defrag.
Auslogics - Download Auslogics Registry Defrag
If you need to repair the registry, then it is best to use the Vista System Restore with a retore point dated before the problem.
    Logitech MX Master 4
I've always used CCleaner, but I've found that registry cleaners are somewhat dependent on who's using them - to a degree, and if you look around the internet you'll find some backup in that registry cleaners are not the end-all of system problems like their makers often purport. Therefore my main motivation for using CCleaner is that it's also an uninstall launcher and cleans up temporary files and so on.
@ Brink -
I've heard a lot about Wise, I guess I'll look that up and give it a try.
    Mobile DualCore AMD Turion 64
    Wistron 30D6
    2048 MB Dual DDR2 SDRAM
    GeForce 7150M / nForce 630M
    160 GB Toshiba MK1637GSX
I would recommend this prog: Auslogics BoostSpeed v4.1.4.135
Ive installed this for no reason and did all their scan/optimization, even if i had no problems, and damn...
I guess i had problems cause now everything is so faster! when i launch apps, games surfing the net, etc... oh and that internet optimizer thing did gave a boost to my downloads for some reason, before it was always capped at like 690kb/sec, and now i hit 760kb/sec... i seriously dindt get this one!
whatever, good prog!
    Q6600 @ 2.4ghz
    EVGA NF650i
    2GB OCZ Gold XTC DDR2 800 MHZ (dual)
    ASUS GeForce 9800GTX
    Drive #1 - Maxtor 6L200P0 (189 GB) Drive #2 - WDC WD2500AAKS-00VSA (232 GB)
Hello dagzag,
-just a FYI last night I ran the Auslogics Registry Defrag- for the first time , not nice , I think it needed to be run in safe mode.
-first I saw the side bar icons corupted -no big deal
-then after a reboot McAfee,would not run -ok. big deal here
-could not reinstall the viris section -control panel blank
-tried to do a system restore but all my restore points including the one that auslogics made were gone !!!--really big deal
-tried windows repair -no luck
-tried my three week old vista back up -no luck
-found at some point , found my drives where renamed as local and single ,could be why the restore points where gone?
-came back to the forums found the sfc/scannow cmd, ran that ,when verify failed to past ,did it 4 times for both ,seemed better, each time smaller CBS file
-just before starting a clean install I removed IE8
-after that I could install McAfee and had my side bar icons back
-all is normal now nothing new in the CBS
-but maybe some checking with IE8 needs to be done with that program
-or I missed something in the set up.
    E8600 @ 4.1
    Asus Striker II Forumla
    4x1 ocz pc8500 @960-4-4-4-12
    2xEvga GTX 285 -sli
    FX Xtreem music--Logitech 5.1 surround
    samsung 2443bw
    1920x1200
    2 x vraptors 150 raid 0 1x seagate 250 gig dump drive
    TX850
    cm690
    Air cooled 2x140mm ,1x120mm ,1x80mm in - 3 120mm out
    Mx518
    g15 + G13
    5mb down -.8mb up
    Apc 1000 UPS for computor NO LONGER USE NOT ENOUGH POWER -200w for the monior
I've been using Wise registry cleaner - the disk cleaner is good too.
I used to use Auslogics registry defrag. tho. am currently using Quicksys - does the same job, and it's smaller and lighter
Quicksys RegDefrag - Defrag, Optimize and Compact Windows Registry
GlaryUtilities is a free all in one I've tried recently - includes lots of tools including regdefrag and file recovery - versions 2.6 on are x64 compatible
www.glarysoft.com
SIW2
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
www.glarysoft.com
SIW2
One for punishment I tried your Quicksys
-same thing McAfee had corruption - that it's utility could not fix.
-side bar icons corrupted -clock black circle with a red line where a clock hand might be,
-restores worked this time ok
-ran sfc/scannow no errors
-soooo I tried it in safe mode -no luck the same problems
-restored again ok
-so is there something wrong in my registry ,or just leave it alone ? any idea's ?
    E8600 @ 4.1
    2xEvga GTX 285 -sli
    samsung 2443bw
    1920x1200
    TX850
    cm690
    Mx518
    g15 + G13
    5mb down -.8mb up
Don't see how registry defrag could cause this problem - did you use a registry cleaner before you tried defragging it ?
If you did , you could try restoring the file the registry cleaner backed up.
Could also be a conflict with McAfee - maybe it "protects" certain registry keys.
SIW2
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
Hi UNTAMED,
I do not see how a registry defragger could do this either. It sounds like McAfee may be blocking something or having problems of it's own as SIW2 suggested. You might consider uninstalling McAfee just as a test to see how your system runs without it.
If you still need to fix your system, then you might try doing a System Restore (Method Two below) using a restore point dated before the problem.
Hi UNTAMED,
The system is running fine as long as I do not defrag the registry , so as you said it would be something with McAfee and Vista 64 (even in safe mode )
-for registry cleaners I only use CCleaner ,and sometimes I will Check off the one in McAfee
-but I did not use either before the defrags.
-when I get some time , I will uninstall McAfee .defrag. then reinstall for a test.
-But the first corruption was worst with IE8 installed.
-in any case , it has me looking for good backup software as the one that comes with the HP dosen't cut it.
-thanks for your time
    E8600 @ 4.1
    2xEvga GTX 285 -sli
    samsung 2443bw
    1920x1200
    TX850
    cm690
    Mx518
    g15 + G13
    5mb down -.8mb up
If you are looking for an alternative to McAfee , you might like the free
www.avast.com the home edition
You can turn off the functions you are not using, e.g. vrdbs, p2p, outlook.
It is a complete product with realtime protection - updates every 4 hrs.You get a free registration key - just need to re-register every 12mths.
I have found it so effective that Windows Defender has never had anything to do. I have had no conflicts with Vista.
Vista has a backup function, of course but you might try another free app, which is very configurable
Karen's Replicator
( you should already have VBRuntime on Vista so don't need to download that as well ).
Hope you find these useful
SIW2
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
No McAfee is great , it's the only software I 'll pay money for. (and OS ),Norton I had lots of problems with in the past , Free -I won't trust it, to run stable.
-as it causing problems with both defragers ,I think even in safe mode the security centre is still active , as the icon is in the task bar ,could hide something in the registry ? to evade attack's who knows.
-vista home prem .dose not come with the full back utities .
-and for full system back ups I seem to be out of luck as the ones I looked at will not restore a clone to raid to my surprise.even the paid versions ($30.00). I'll keep looking.
    E8600 @ 4.1
    2xEvga GTX 285 -sli
    samsung 2443bw
    1920x1200
    TX850
    cm690
    Mx518
    g15 + G13
    5mb down -.8mb up
Acronis True Image Home 11. Saved my butt more than once. You might want to inquire about 64 bit compatability.
    Dell Dimension 8400
    2 G
    1 G
    Dell 20" flat screen
    1360 x 1024
    2 160GB
    Cable
-Thank's , I just picked that up last week for $9.99 (on sale),it seems really good.and it works on 64bit.
-I did a clean install , then started the back ups.
    E8600 @ 4.1
    2xEvga GTX 285 -sli
    samsung 2443bw
    1920x1200
    TX850
    cm690
    Mx518
    g15 + G13
    5mb down -.8mb up
