Reinstalling driver for SD memory card reader
ilikefree
2,877
Location
New Zealand
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
39
Location
Wisconsin
If you do a system restore the old driver should come back. Is the SD card reader external? You can try disconnecting the card reader and reconnecting it. That might cause the found new hardware wizard to pop up. Otherwise i would try the driver ilikefree posted in his link.
    Toshiba Laptop A505 S6965
    Intel Core2 Duo P7350 2.0Ghz
    4Gb DDR2
    ATI Mobility Radeon HD 4570 (512MB)
    16in.
    1366x768
    500gig
    10Mb/896Kb
ilikefree
2,877
Location
New Zealand
Go to device manager and update the driver when it asks if you would like to go on line or browse your computer say browse and go to the file you downloaded from the link I gave you earlier
    LENOVO 64734VM
    15 inch
    External Speakers
