Remote Desktop Help
Okay you networking gurus I need some help. I have a machine at home running Vista and one at work running Vista and would like to use remote desktop to my work machine so I can work from home when I need to. I am hoping I can use the setup in Vista without having to buy Gotomypc.
I can make the remote desktop work flawlessly in the office between two machines but I cannot access my office from home for some reason.
Anyone with experience at this HELP!
    AMD Phenom 9950
    Gigabyte 790FX-DS5
    8 Gig G.Skill DDR2 800
    Visiontek 4850
    Seagate 7200.11 500 Gig
johngalt
Antidisestablishmentarian
RD will require various special ports forwarded on your router (if you have one) and ports allowed in your firewall (Vista by default has a firewall, so even if you haven't installed one it is there) before you can do it.
Another solution would be to use VPN, see the VPN thread in this forum as well.
    The Beast Model V
    eVGA X58 Classified3
    3 * 4GB Mushkin Enhanced Redline CL7 DDR3 1600 MHz (PC3-12800)
    eVGA GTX 970 + eVGA GTX 560 Ti 448 Core Calssified (PhysX)
    Realtek HD Audio (onboard)
    2 * Lenovo LT2323pwA
    2 * 1920 x 1080
    2 * Seagate Barracuda 7200.12 ST31000528AS 1TB 7200 RPM SATA II
    Seagate Barracuda 7200.12 ST1500DL001 1.5 TB SATA II
    ThermalTake BlackWidow 850W
    ThermalTake Level 10 GT
    Corsair H100 (CPU) + Air (2 * 210 mm + 3 * 120mm fans)
    Logitech MX Master
    Logitech G15 (gen 2)
    180 Mbit down / 15 Mbit up
    3 VMs built off IP 14971:
    UUP disabled / single VHD | UUP disabled / dual VHDs with moved \User Tree | UUP enabled / single VHD
Can you giveme the port info to setup the roputer or point me to the location of the information?
    AMD Phenom 9950
    Gigabyte 790FX-DS5
    Visiontek 4850
Freelancer852
Vista Vet
Vista Pro
    Acropolis
    Intel Core i7-6800k @ 4.0 GHz
    ASUS X99-M WS
    32GB Corsair Vengeance 2x16GB
    ASUS GeForce GTX 1080 STRIX
    ASUS ROG Swift PG278Q
    2x 256GB Samsung 850 Pro (RAID 0)
    1x 500GB Samsung 850 Evo
    2x Western Digital RED 4TB (RAID 1)
    50TB File Server (Multiple RAID 6)
    Corsair AX1200i
    Corsair Air 240
    Logitech G502
    Razer Blackwidow X Chroma
    250Mbps Down | 15 Mbps Up
