Resize Hiberfil.sys
109
Can Vista's Hiberfil.sys file be resized down to 75% ?
If so what is the proper command?
From an elevated command prompt window without success I have tried;
PowerCfg.exe /HIBERNATE /SIZE 75, and powercfg -h -size 75
Both return "Invalid Parameters"
All help appreciated
Thanks
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
Hello Glatzfront,
Double check to see if hibernate is enabled and that you have the hidden C:\hiberfil.sys file.
powercfg -h -on
Hope this helps for now,
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
Where you ever able to resize it?
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
townsbg
~~тσωηsвg~~
2,248
Location
US of A
Hiberfil.sys is the file where data that is in memory is stored on the hard drive when you put your computer into hibernation. It must be the same size as the amount of memory that you have to ensure that windows has enough hard drive space to go into hibernation. Therefore it can't be resized however hibernation can be disabled. How to disable and re-enable hibernation on a computer that is running Windows Disabling hibernation will eliminate that file.
    Mid 2010 iMac
    3.2 Ghz I3
    8 gb
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
109
I've never tried or even considered it before.
Yep, it can be resized, but it is best to set it or leave it at 100%. ;)
Hibernate - Change Size of hiberfil.sys File - Windows 7 Forums
At times disk space has become critical on the Vista partition and sometime soon I'll be resizing. I put Vista on a 40 GB partition which of course is to small. As a temporary measure I want 75%, like the default size in Win 7.
I'm also trying to reduce the size of the Page file but the Mini dump wont hold for long before it reverts back to the kernel dump, don't know why??? The way I use my computer I don't think I'll have any issues with smaller Hiberfil and Page files. Moving the Page file might cause some loss of performance so it is second to the smaller size.
