restart problem
kev s148
Power User
Hi iam hope some body can help me
Ive just finished building a new computer and everything went fine but about 3 days after it was up and runing i recived my internal card reader.
I installed it and every think semt fine but after in stall of the card reader every time i do a restart the computer switchs off when it comes back on it is not booting from the hard drive it is trying to boot from the dvd drive.
I have unpluged the dvd drive and tryed again but it will still not try and boot from the hard drive but if i switch the computer off all togeather and then restart it it boot from the hard drive.
I have even tryed a system restore and that has not helped.
So any help or suggestions would be greatful
by the way i have removed the card reader
thank you in advance
    home built
    Intel Core i7 920 2.66ghz @ 3.67ghz 1.3v
    ASUS P6T Deluxe V2 iX58
    6GB (3x2GB) Corsair Dominator DDR3 [email protected] 8-8-8-24
    BFG GTX 285 OCX
    on board
    samsung t220 sync master
    1TB samsung
    Corsair HX1000W
    antec 902
    Zalman CNPS10X Extreme Ultra Quiet x3 120mm + 200mm fans
    Microsoft Wireless Laser Desktop 7000
    6mb
    LG dvd-rw, LG GGC-H20L blueray player, Sony 2.1 speakers system, HP photosmart c5180 All-in-one Printer/Scanner/Copier (network conected) NetGear DG834G v4 ADSL Modem/Router (Ethernet) netgear GS608 8 port switch WEI Score: 5.9
scrooge
Vista Pro
did you check your bios and make sure the harddrive is set for your first boot drive?
are thay ide drives ? if so you have to set them up as (master and slave) the harddrive being the master drive..
scrooge
    Intel Core 2 Duo E8400 / 3.00
    ASUS P5K-E/WIFI-AP LGA 775 Int
    G.SKILL 4GB (2 x 2GB)
    SAPPHIRE 100225L Radeon HD 387
    1 x 1tb western digital
    4 x 250 western digital
    2 x 160 western digital
    1 x 320 western digital
kev s148
Power User
hi yes ive set the hard drive as the first boot drive and no there are no ide drives just runing of sata
thank you
    home built
    BFG GTX 285 OCX
    on board
    1TB samsung
    Corsair HX1000W
    antec 902
    6mb
