Solved Restore SoftwareDistribution Folder?
townsbg
~~тσωηsвg~~
Long story short after the last round of updates I corrupted my Vista VM. I copied the original hard drive file to my 7 VM and restored the data just in case I couldn't get windows back. When doing so I had to run chkdsk which fixed some problems and allowed me to recover what few files I have in the VM. Today I did a repair by booting into the installation disk and selecting the repair option. I am back and operational but I no longer have my update history since my SoftwareDistribution folder has been replaced. I can access the original hard drive file and recover that folder provided that it isn't corrupt. Should I do that or is it not worth the risk? At this point Windows has no idea if updates have ever been installed and based on what happened I'm not sure if the last round of updates where retained.
    Windows 7 Pro x64
    Mid 2010 iMac
    Quad core 3.2 Ghz Intel I3
    8 gb
    ATI Radeon HD 5670 512 mb ram
    1920x1080 and 1440x900
    1 TB
    N/A
    Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1440 x 900
    1 TB & 360 GB
Jody Thornton
Power User
So when you enabled the Windows Update service, and checked again for updates, did it recreate a Datastore.edb file? That should contain what updates are installed and then generate a list of what updates are now needed.
    Windows 8 Pro x64
    HP xw8600 Workstation
    Two Intel Xeon Core2 Quad 3.2 GHz Processors
    Proprietary
    16 GB DDR2 800 MHz
    nVidia Quadro FX 3800 PCI-E
    Realtek HD Audio
    Samsung SyncMaster 213T 21" 4x3 Flat Screen
    1600x1200
    Two Seagate Cheetah 300 GB SAS Disks
    Proprietary
    HP xw8600 Workstation Case
    Two CPU Fans and One Larger Cooling Fan
    Microsoft USB Optical Mouse
    PS/2 Keyboard
    7 mbps
    Storage Interface: Two LSI 3000 SAS Adapters
    Browser: Waterfox G3.0.2 (based on Firefox ESR 78.6)
