Solved restore to factory settings
3
ok im tryimg to restore my dell inspiron 1525 laptop to factory settings.(also i run vista home premium 32bit). I have tried the f8 advancted options and people say i should see a command to restore to factory settings but it dosent show up for me. can anyone help me out
SIW2
2,741
Hi ZAPP,
Backup any data you need to keep first.
Here are the instructions :
Dell - Support
If they don't work for you, you have two options:
1. Boot the Dell dvd and reinstall using that ( if you have one)
Or
2. Mark the Recovery partition active ( sometimes called Flagged On ) and restart. The recovery program should start .
To Flag On the recovery partition , you would use a bootable partition manager, GParted is a free one here:
http://sourceforge.net/project/showfiles.php?group_id=115843&package_id=271779&release_id=683279
SourceForge.net: GParted: Files
It downloads as an .iso file.
Burn that .iso to a cd - do not format the cd.
Use this .iso burner :
View attachment Burn CDCC.zip
Boot the cd you just made -it will load into memory and show your Hard drive.
Rt click the recovery partition ( it will smallish 6-10GB) and select Flag On , then click Apply.
The recovery partition should now say "boot" next to it.
Remove the cd and restart the pc.
    Intel E8400
    ASRock1333-GLAN R2.0
    2gb DDR2 800
    nvidia 9500GT 1gb
kavita
CCNA
Vista Pro
276
Location
India
when you press f8, select Repair Your Computer and press enter.
after entering username and pswd, you will enter Windows recovery environment and select Dell factory image restore option.
    Intel Dual Core 3 GHz
    3 GB DDR 2 667 Mhz
    ATI X1550 256 MB
    Samsung 19"
    80 GB IDE Samsung.
    iBall
    iBall
    2mbps
3
thanks siw2 i found my operations disk and got my computer back to what it was but now i have another problem. my computer will not let me get on the internet and some of my drivers have a yellow ! by them but it will not let me reinstall them or anything.
usasma
Old and cranky
1,364
Location
Southeastern CT, USA
Using another computer, go to Dell - Drivers and Downloads and enter your service tag number to access the drivers for your system.
Download them to a CD/DVD (or a flash drive), then put that in your computer and install them. If any yellow !'s or red x's remain, let us know what they are and we'll try to come up with drivers for them.
SIW2
2,741
Hi zapp,
How do you mean it won't let you install them?
Do you have the driver installers on a cd ?
    Intel E8400
    2gb DDR2 800
    nvidia 9500GT 1gb
SIW2
2,741
#8
Hi ZAPP,
Glad it's working for you now.:D
    Intel E8400
    2gb DDR2 800
    nvidia 9500GT 1gb
