right-click context menu
Nikilet
I discovered this evening that I no longer have "Run as administrator" on my right-click context menu. But that isn't altogether true. I discovered that I can go to Start/All Programs and "Run as administrator" does appear on almost everything I right clicked there. For instance, I was told to run the AIS setup.exe file as administrator. That's when I discovered that option no longer appears. Can someone please help me? Please!!! Vista SP2 320 GB Hard drive 4 GB RAM
    Dell DXP061
    1.87 gigahertz Intel Core 2 Duo
    High Definition Audio Device
    NVIDIA GeForce 7300 LE DELL E207WFP [Monitor] 20"
    SAMSUNG HD321KJ [Hard drive] (320.07 GB)
    DSL
    Avast Internet Security 7 / Malwarebytes Pro / WinPatrol Plus / Secunit PSI /
Re: right-click context menu / Check Disk not working?
I posted a reply to this and it didn't show up. What I wanted to know was what "open with" would have to do with the "run as administrator" command not showing up. I just tried to run Check Disk. On restart the page came up, listed the file system, etc., then said the system was clean -- I mean immediately -- and then went right to the restart. I tried it again and this time it didn't even bring up the black Check Disk screen with white lettering. It just started like normal. I don't now what to do. My restore points only go back to the 26th so I don't think it will do any good to do a System Restore. Can anyone help me?
    Dell DXP061
    DSL
Hello Nikilet,
Please see if you may be able to have the AIS setup.exe file "run as administrator" using one of the options in the tutorial below instead.
Run as Administrator - Windows 7 Forums
I can run AIS setup as administrator by going into properties/compatibility tab and selecting to run as administrator, but I should be able to do it through my right-click context menu, like I always have in the past. I haven't had time to go through all the other options on the link you so kindly provided. But I did notice something I'm wondering about. Under default programs/associate a file type or protocol with a program, there is absolutely nothing in this long list for .zip. Shouldn't there be something?
    Dell DXP061
    DSL
Nikilet,
Is "Run as administrator" missing from the context menu of any other application files?
Strangely .zip is not listed in Default Programs. Are you having any issues with creating a ZIP folder?
First, I was finally able to get Check Disk to run. It took a long time and I sat right by the computer so I wouldn't miss anything. There was no indication shown of any problems. However, I found reference to a command you can type into the Start box to get a log file of these Check Disk scans. The command is sfcdetails.txt Following is what it said:
Note The Sfcdetails.txt file contains details from every time that the System File Checker tool has been run on the computer. The file includes information about files that were not repaired by the System File Checker tool. Verify the date and time entries to determine the problem files that were found the last time that you ran the System File Checker tool.
OK - so why is there no info on the page regarding the scan I ran in the wee hours of this morning? In fact, the only date on it is 2-23-2011, and I have run Check Disk a number of times.
Next, your question: Is Run as administrator missing from the context menu of any other application files? I can go to the start menu and anything I have pinned there DOES have Run as administrator (RAS) on the right-click menu. Also, when I open All Programs, I can right click within that and RAS is on the menu. But nowhere else on my computer can I get this command through the right-click menu -- not from the desk top, not from within Program Files in C drive.
I feel I need to explain further. The way this all started was over my Avast Internet Security right-click scan option and I think that and this has to be tied to one problem, whatever it is. I discovered when I would right click an item and then select to scan that item with Avast, it was not performing a scan. I have always saved all email attachments to my desktop and then scanned with Avast before opening. I could no longer do that. Through the right-click menu, I can scan some things -- like exe files, program files -- but I can NOT scan jpg, wmv, zip, pps ....... Unless I place them in a FOLDER first. I can right-click the folder and select to scan it with Avast and it will then scan all the items within the folder -- but it will not scan an individual item. The KEY is having the items inside a folder first, and then selecting the folder to scan. Just like the KEY to run as administrator seems to be to have it in the Start menu. Doesn't make any sense. Please see what is listed for zip in attached screenshot. I created a zip file and it seemed to go fine, except for another bit of strangeness. When I created it I click 7-Zip, which was BOLDED in the menu and nothing was there. Then I went to Send to and selected zip folder and all went well. When I tried to unzip it I selected Extract all and nothing happened. Then, I had to go to 7-Zip to get it to extract. There is just something very strange going on here. I am typing paragraphs, but when I clicked on Preview everything was all run together which made if very hard to read. I again split things up but don't know if it will stay that way.
    Dell DXP061
    DSL
This post above is a mess. Twice I split things into paragraphs and it comes out all run together, and everywhere I put quotes around something it comes out looking like this "Preview" I changed all this twice. I see you were able to split things up. WHAT IS GOING ON HERE!!!??? This should have come out in two paragraphs and again it is all run together.
    Dell DXP061
    DSL
Hello Nikilet,
What did you copy and paste the post from?
You may need to click on the a/A icon button at the top right corner of the post while editing to switch editor mode, then copy and past the message.
You may have cleared the SFC details from the CBS.log file if you ran Disk Cleanup or a program like CCleaner that clears logs?
Could you upload your current sfcdetails.txt file to see what it has listed as not repairable.
Were you able to read through that scrunched up mess then? I didn't copy and paste the post. I just typed it and when I clicked on Preview I seen it was all run together so while it was in Preview, I went through and spaced things out. But when I clicked Submit it came through still all run together. I'm clicking on that a/A button and absolutely nothing is happening. There are NO items in that sfcdetails.txt log that were not repaired. There were two items in it, and both were repaired some time ago. I don't know what's going on in here, but this is all run together again. I am not having this problem in the Avast forum, where I am also working right now.
    Dell DXP061
    DSL
I'm not sure what may be causing your post to run together like that.
What web browser are you using?
Have you installed any add-ons (IE) or plug-ins (Firefox)?
I use Firefox, same as always. No, I haven't installed anything new for a while. Guess that's the least of my problems right now. Maybe it's just all a part of the problems I'm having. As to what you said earlier about logs having been cleared because of something like CCleaner -- I get that but I just performed this scan and no such program has been used. All of a sudden I'm having a lot of little anomolies with the operation of this computer. I feel sure it is not an infection because I am very security minded and I take care that everything is kept updated, etc. It appears I'm going to be advised to uninstall, and then reinstall Avast in hopes of curing that right-click scan problem. I just don't get it. My computer is running fine, but I'm having all these strange things coming up with the right-click menu.
    Dell DXP061
    DSL
You never commented on the screenshot of what it showed in defaults for zip -- and what I explained to you about that.
    Dell DXP061
    DSL
That's normal for ZIP files. It's not listed in Default Programs.
You might give Method 2 a try at the link below to see if it might be able to help you find out what is causing your context menu issues.
As a test, create a new administrator account to see if you have the same issues while logged in it.
Hello Brink! It doesn't seem like we are really making any kind of progress here with my problem, and I can't seem to post in this form without everything running together and being hard to read. I found a registry file in my Googling called RunAsAdmin_add.reg. It was taken from a post in a Windows forum and it supposedly adds this "Run as administrator" back to the registry. I don't know if it's safe to use something like this or not. There should be a place in the registry where I can look to see whether this or that is right so I can tell if it is a registry problem but I wouldn't know where to look. Can you help me with that? Knowing where to look in the registry to find out if this command is messed up there?
    Dell DXP061
    DSL
I'd hate to say this, but with all the different issues that you are having, you may be better of starting with a new clean install of Vista instead so that you can start fresh again. :(
I'm just not ready for that. Actually, it's just the context menu and although it's inconvenience and aggravating as all get-out -- I don't think that's serious enough to go to the work and hassle of reinstalling the OS.
    Dell DXP061
    DSL
