router vs. switch
Waht is the difference between a ethernet switch and a ethernet router? Which one is better? Do you need the router first before you can use the switch?
    Self built
    AMD Athlon 64x2 6000+ 3.0ghz
    Asus M4N78 Pro
    3Gb PC2-5300 DDR2 @ 667mhz
    VIA HD Audio
    OEM HP
    OEM HP
