Roxio wants a certificate
Peppurr101
Power User
Hi all,
Since a Factory Image reinstall on my system I have not been able to get my Roxio Easy Media Creator to work. When I click on any of the icons, it says that the 'certificate is invalid or corrupted' and wants me to reinstall it.
Is there some way of repairing this short of a complete reinstall? I have the Roxio disk supplied by Dell and I was hoping to get away with not having to completely reinstall the program. I have no luck with that stuff.:shock:
Thanks
Peppurr
And Happy New Year to all! :party:
Dell 420XPS running Windows Vista Home Premium 32 bit
4GB dual channel DDR2 667MHZ [4x 1024]
500G Data Safe local hard drive
DVD+/-RW 16x max and DVD 16x reader
20" wide flat panel monitor
Single 768MB nVidia GeForce 8800GTX
Sound Blaster X-Fi Xtreme Gamer PCI soundcard
TV Tuner and AVIO Accelerator
Internal V.92 PCI Data Fax modem
Speedtouch 330 external USB broadband modem
Norton Internet Security
Adobe Reader 7.0.8
MS Office 2007 Home and Student
Standard mouse keyboard and speakers
etc
    Dell XPS 420
    Intel (R) Core(TM) Quad 6600 @2.4GHz
    NVIDIA GeForce 8800 GTX
    Creative SB X-Fi
    Generic Dell PnP Monitor
    2 500GB Hard drives in a RAID 1 Mirror configuration.
    Standard optical mouse
    Standard USB QWERTY keyboard
    Actual 2.2 Mbps
    Connected to DSL internet via ethernet via Netgear DGN2000 modem router.
    Also connected via ethernet to HP 8180 All-in-One Photosmart printer.
    19-in1 card reader and 1 DVD and 1 DVD RW drives
    Country Flag
    uk
    State/Region Flag
    us new jersey
Airbot
    Airbot 2.0
    EVGA Nvidia GTX 480 -Fermi
    ASUS Xonar D2X
    [email protected]
    1 OCZ Vertex2 180GB SSD
    Pioneer DVD Burner DVR-S18M
    Corsair HX1000W
    Cooler Master HAF 932
    Logitech Wireless MK700
    Windows 7
    W.E.I final score= 7.7
    Windows Vista=5.9
SCSIraidGURU
Repair install from add/remove.
    16GB DDR667
    SAS RAID
Peppurr101
Power User
Hi all,
THank you for your replies.
SCSIraidGuru, do you mean Programs and Features? I did look there but I have about 10 Roxio Applications listed and don't know where to start.
They are:
Roxio Activation Module
Roxio Creator Audio
Roxio Creator BDAV Plugin
Roxio Creator Copy
Roxio Creator Data
Roxio Creator Premier
Roxio Creator Tools
Roxio EasyArchive
Roxio Express Labeler
Roxio MyDVD Premier
Roxio Update Manager
and
Sonic CinePlayer Decoder Pack (which has a Roxio Icon)
Very confused..
Any help would be appreciated.
Airbot,
Would the SFC be good for the Roxio stuff? No problems in vista itself
Thanks
    Dell XPS 420
    Creative SB X-Fi
    Actual 2.2 Mbps
    Country Flag
    uk
    State/Region Flag
    us new jersey
RedDawn
Hi Peppurr101,
I had something similar happen to me with Roxio after a Factory Image reinstall.
All you need to do is insert your Roxio disk and follow the simple steps to reinstall, it is quite an easy procedure and will automatically remove your old Roxio. Remember to restart your computer when finished.
Hope this helps.:)
  • Country Flag
    ireland
Peppurr101
Power User
Hi Red Dawn,
Thank you for your reply and I'm sorry I missed it.:o
I did go over to the Roxio boards and came up with a really complicated tutorial the recommended I completely take out my old Roxio (including some really scary go into the registry instructions) before re-installing.
I just want to clarify. You put the CD in and re-installed over the installed version of Roxio Easy Media Creator?
Did you have to 'run as administrator'?
If I upgrade, will that solve it? I am thinking of getting an HP 8180 printer and I think that comes with some kind of Roxio software.
Thanks
Liz
PS Do I remember seeing you over at Dell?
:rolleyes:
    Dell XPS 420
    Creative SB X-Fi
    Actual 2.2 Mbps
    Country Flag
    uk
    State/Region Flag
    us new jersey
RedDawn
Hi Liz,
I just want to clarify. You put the CD in and re-installed over the installed version of Roxio Easy Media Creator? Did you have to 'run as administrator'?
Yes, when I completed my Factory Image reinstall, Roxio wouldn't work, saying that the trial had expired (? it wasn't a trial to begin with :confused:), I just inserted my Roxio CD and ran it. It gave simple to follow prompts that uninstalled the previous and installed a fresh copy. Can't remember if I ran it as administrator or not.
My problem was a little different than yours and my Roxio components in Add/Remove are slightly different too, but I can't see why applying the same solution wouldn't work, certainly can't hurt to try.
Not sure, I wouldn't think though that any software supplied with a printer would contain DVD/CD editing (maybe photo editing?), again I really can't say for sure.
yeah, I'm a bit of a forum junkie :D.
  • Country Flag
    ireland
Peppurr101
Power User
    Dell XPS 420
    Creative SB X-Fi
    Actual 2.2 Mbps
    Country Flag
    uk
    State/Region Flag
    us new jersey
