rundll32 stops working
5
Hi, I am on windows vista sp1 home premium, and I often get a problem
saying rundll32 has stopped working:mad:. I googled and found out that this
is often caused due to nero's codecs which interfere with vista:rolleyes:, but I
have neither nero nor roxio installed, except that I use the latest
version of vista codec pack. I just checked out by disabling startup
services in msconfig and rebooting each time, but it's all the same
every time:huh:, the problem just keeps repeating. I often get the problem
on resuming from standby:sleepy:. Can anybody recommend a solution? BTW, i am
on an HP Pavilion dvt6846tx.
Problem log from "Problem Reports and Solutions":Product
Windows host process (Rundll32)
Problem
Stopped working
Date
21-09-2008 14:00
Status
Report Sent
Problem signature
Problem Event Name: APPCRASH
Application Name: rundll32.exe
Application Version: 6.0.6000.16386
Application Timestamp: 4549b0e1
Fault Module Name: USER32.dll
Fault Module Version: 6.0.6001.18000
Fault Module Timestamp: 4791a7a6
Exception Code: c0000142
Exception Offset: 00009cac
OS Version: 6.0.6001.2.1.0.768.3
Locale ID: 16393
Additional Information 1: 9d13
Additional Information 2: 1abee00edb3fc1158f9ad6f44f0f6be8
Additional Information 3: 9d13
Additional Information 4: 1abee00edb3fc1158f9ad6f44f0f6be8
Extra information about the problem
Bucket ID: 633174191
    HP Pavilion dv6846tx
    Intel(R) Mobile Core(TM)2 Duo T5600 @1.83 GHz
    Quanta 30D2
    3 GB DDR2
    NVIDIA Geforce 8400M GS
    Realtek HD Audio
    Laptop LCD display 15.4"
    TOSHIBA MK3252GSX 320 GB
    Laptop PSU
    Laptop
    Laptop fan
    Microsoft Basic Optical Mouse v2.0
    HP Laptop Keyboard with Quickplay buttons
    DSL 384 kbps
Barman58
Staff member
1,807
Location
Newport, South Wales, UK
hello vikraman09, and welcome to the forums, :party:
if you check the error detail that you posted the actual fault module is stated as USER32.DLL
you may want to check this tutorial and run the system file check as shown.
hopefully this may solve the problem, if not post back with any output from SFC
    Windows 10 Pro 1709 Fall Creators Update (16299.192)
    Asus M5A78L-M USB3
    32GB [4x8GB] DDR3 1600 MHz
    Asus nVidia GTX750TI-OC-2GD5 (2GB DDR5)
    2 x 1920x1080 @50Hz
    Internal
    Crucial CT256MX100SSD1 256GB SSD,
    WDC WD30EZRX-00D8PB0 3TB,
    Toshiba HDWD130 3TB
    Seagate ST2000DM001-1CH1 2TB,
    External (USB3)
    Seagate Backup+ Hub BK SCSI Disk 8TB
    2.5/3.5 Hot Swap Cradle, USB3 + eSata (client HDDs)
    NAS 4TB +1TB
    Wireless Logitec - MX Master + M570 Trackball
    Wireless Logitec MK710 + K400+
    37.8 MB Down 9.5 MB Up
5
I ran a sfc /verifyonly from an elevated command prompt and the output is as follows:
C:\Windows\system32>sfc /verifyonly
Beginning system scan. This process will take some time.
Beginning verification phase of system scan.
Verification 100% complete.
Windows Resource Protection did not find any integrity violations.
    Quanta 30D2
    3 GB DDR2
    Realtek HD Audio
    Laptop PSU
    Laptop
    Laptop fan
    DSL 384 kbps
5
Hey, I also checked out the processes running in task manager, and I actually found two rundll32.exe processes, one running under the SYSTEM account (2196k mem) and one running under my account, ie, the user logged in. Is this normal? Both are located at C:\WINDOWS\system32\rundll32.exe
    Quanta 30D2
    3 GB DDR2
    Realtek HD Audio
    Laptop PSU
    Laptop
    Laptop fan
    DSL 384 kbps
Barman58
Staff member
1,807
Location
rundll32.exe is a windows catch-all program so multiple copies are usual and notheing to worry about. will try and investigate a little more on your original error and post back :)
    Asus M5A78L-M USB3
    2 x 1920x1080 @50Hz
    Internal
    Toshiba HDWD130 3TB
    External (USB3)
    NAS 4TB +1TB
5
;)Thanks for your quick reply
    Quanta 30D2
    3 GB DDR2
    Realtek HD Audio
    Laptop PSU
    Laptop
    Laptop fan
    DSL 384 kbps
Barman58
Staff member
1,807
Location
OK, I've had some time to check into the error (bucket ID 1066512) and guess what? the definitive answer on Microsoft technet leads to one answer that suggests that you search for an answer :confused:
it looks as if this problem is still in Microsoft's to-do pile :) there is quite a lot of references to the actual error but all lead to nowhere or the technet article
I'm afraid for the present you may have to put up with the error until Microsoft come up with an answer. as far as I can understand the error is Self healing in that apart from the error itself it does not appear to cause other problems.
if any other members have any further information please post
    Asus M5A78L-M USB3
    2 x 1920x1080 @50Hz
    Internal
    Toshiba HDWD130 3TB
    External (USB3)
    NAS 4TB +1TB
5
#8
:DOk, thanks for your help
    Quanta 30D2
    3 GB DDR2
    Realtek HD Audio
    Laptop PSU
    Laptop
    Laptop fan
    DSL 384 kbps
