Samsung 226BW with 8800GTS - Magictune doesn't work
glob
Power User
Used the Magictune software under Windows XP (32 bit) no problem. Have the latest drivers installed for both the Samsung monitor and 8800GTS card. But when I install and run Magictune (the 64 bit version) it says it doesn't work with this monitor! Any ideas?
You can't run x64 Apps on a Windows x32! Try getting a 32Bit version.
Oops, just realised his sig says Ultimate x64.. :P
but anyway this is quoted from Samsungs own support page (SAMSUNG’s Digital World - Monitor / Awards)
MagicTune Program is an additional program for monitor products.
Some of the computing system installed either old or the latest video card can not be compatible with Magic Tune.
Please visit the MagicTune Website for technical support for MagicTune.
You could try here? : SAMSUNG’s Digital World - Monitor / Awards
EDIT:
Implemented Models
The following Samsung LCD/CDT monitors have implemented MagicTune.
Area Model
CDT Monitor SyncMaster 591v, 591s, 592v, 592s, 793v, 793s, 794v, 794s
SyncMaster 783DF, 788DF, 793DF, 795DF, 797DF, 997DF
SyncMaster 793MB(+), 795MB(+), 797MB, 997MB
LCD Monitor SyncMaster 152x, 172x
SyncMaster 152N, 172N, 192N, 153T, 173T, 174T, 193T
SyncMaster 510M, 710M, 910M, 710V, 910V
SyncMaster 510N, 710N, 910N, 510T, 710T, 910T, 913N
SyncMaster 720B, 721B, 720T, 920T
Syncmaster 510T, 515V*, 512N*, 710T, 711T, 710TM, 712N*, 910T, 912T, 913N, 913T, 910TM, 912N*, 915N*
Syncmaster 510M, 710V, 710M, 73V, 74V, 713V*, 715V*,910V, 910M, 913V, 93V, 94V, 915V*
Syncmaster 730B, 930B
Syncmaster 173P Plus, 193P Plus
Got any of those monitors?
nope...its called 226bw...sorry i guess i'll look it up because i got the same software...yea me too way too tired...give me about 30 min and i'll get u the link
What I was saying in my original post was that it all worked well when I ran Windows XP. Now that I've upgraded to Vista x64 it doesn't work when I use the 64-bit version of the software (still the same monitor).
Oh well, I'll put it down to a combination of Vista x64 and the 64-bit version not supportingthe same monitors as the older XP 32-bit version of Magictune.
Are you using a Windows XP x64 application? Because is it (apparently) different from the Vista x64 application...
Hi Panzer,
You can get the driver here. The latest version is 1.0. Just click on the icon under File to download it. I'm not sure if Vista means for both the 32 bit and 64 bit or not since they have XP and XP64 listed too. You can give it a try and see with the Vista or XP64 one.
download center SAMSUNG
    Logitech MX Master 4
Hi. I have a 226BW and am running Vista 64x. I tried all sorts of things to get this Magictune but it just doesn't seem to work in 64 bit.
Over the last few days MS Update tried to download an update for Samsung 226BW but it failed. I've tried to do it manually but cannot so I don't know what difference it might have made.
On the other hand. The drivers that Vista found automatically make it look fantastic, great colour and definition etc.
I can't think that Magictune could improve on it so I stopped worrying about it months ago and just enjoy this great monitor.:D John
    custom build
    Q6600 OCd to 3.06GHz
    Asus P5Q Pro
    Corsair 2x2GB TWIN2X4096-8500C5DF G
    XFX GTX 260 Black Edition
    Dell Utrasharp 2408WFP
    1920x1200
    2x Samsung Spinpoint 500GB 1x Samsung F1 1TB
    Thermaltake Toughpower 650 watt
    Coolermaster Cosmos S
    Tuniq Tower 120 + 3x120mm + 200m side fan
    Roccat Kone
    logitech Wave
    supposedly 8mbps actually about 4 or 5
    love this mouse
    self-built
    Intel Core2Quad Q9650 @ 3.4 GHz
    Asus P5Q Premium
    4 x 2 gigs Patriot DDR2 6400 5-5-5-12
    EVGA SC GTX 280 (for graphics); Asus en8800GT (for PhysX)
    on-board SoundMax 7:1
    2 x Samsung SyncMaster T240
    1920 x 1200 (each)
    4 x WD320 (YS) SATA2 HDD and 1 x WD500 (AAKS) SATA2 HDD set as AHCI
    Silverstone OP1000-E
    Antec Nine Hundred
    OCZ Vendetta 2
    Logitech MX518
    Unicomp spacesaver (with buckling springs) hey hey!!
    Down: 6700 kbps; Up: 800 kbps
You're totally right, Magic Tune does not work. I'm glad the buttons on the side of the T240 have the magic tunes functions (Gaming, Internet, etc.).
lolz
Vladsky
    self-built
    Asus P5Q Premium
    1920 x 1200 (each)
    Antec Nine Hundred
    OCZ Vendetta 2
    Logitech MX518
