Solved Script to parse .txt & move Computer Accounts to different OU
re: Script to parse .txt & move Computer Accounts to different OU
Try this, report back :) I probably have not got it right first time, but have corrected two syntax errors.
Option Explicit
Dim strFile, strTargetOU, objFSO, objFile, objOU
Dim objRootDSE, strDNSDomain, objTrans, strNetBIOSDomain
Dim strComputer, strComputerDN, objComputer
Const ADS_NAME_INITTYPE_DOMAIN = 1
Const ADS_NAME_TYPE_NT4 = 3
Const ADS_NAME_TYPE_1179 = 1
' Specify text file of computer NetBIOS names.
strFile = "c:\Computers.txt"
' Specify target OU to move computer objects into.
strTargetOU = "ou=SrAccounts,dc=MyDomain,dc=com"
' Open the file for read access.
Set objFSO = CreateObject("Scripting.FileSystemObject")
Set objFile = objFSO.OpenTextFile(strFile, 1)
' Bind to the target OU.
Set objOU = GetObject("LDAP://" & strTargetOU)
' Determine DNS domain name from RootDSE object.
Set objRootDSE = GetObject("LDAP://RootDSE")
strDNSDomain = objRootDSE.Get("DefaultNamingContext")
' Use the NameTranslate object to find the NetBIOS domain name from
' the DNS domain name.
Set objTrans = CreateObject("NameTranslate")
objTrans.Init ADS_NAME_TYPE_NT4, strDNSDomain
objTrans.Set ADS_NAME_TYPE_1179, strDNSDomain
strNetBIOSDomain = objTrans.Get(ADS_NAME_TYPE_NT4)
' Remove trailing backslash.
strNetBIOSDomain = Left(strNetBIOSDomain, Len(strNetBIOSDomain) - 1)
' Use the NameTranslate object to convert computer NetBIOS
' names to Distinguished Names.
objTrans.Init ADS_NAME_INITTYPE_DOMAIN, strNetBIOSDomain
' Read lines from the file.
Do Until objFile.AtEndOfStream
strComputer = Trim(objFile.ReadLine)
If (strComputer <> "") Then
' Convert NetBIOS name to DN.
' NetBIOS name must have "$" appended to end.
' Trap error if computer not found.
On Error Resume Next
objTrans.Set ADS_NAME_TYPE_NT4, strNetBIOSDomain & "\" & strComputer & "$"
If (Err.Number <> 0) Then
On Error Goto 0
Wscript.Echo "Computer not found: " & strComputer
Else
On Error GoTo 0
strComputerDN = objTrans.Get(ADS_NAME_TYPE_1179)
' Bind to the computer object.
Set objComputer = GetObject("LDAP://" & strComputerDN)
' Move the computer object to the target OU.
objTargetOU.MoveHere objComputer.AdsPath, vbNullString
End If
End If
Loop
Wscript.Echo "Done"
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    1 x 640Gb (SATA 300)
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Thanks for the quick reply!!
Now I'm getting this:
Line: 97
Char: 1
Error: Variable is undefined: 'objTargetOU'
Obviously, that means there is no declaration. However, since that is the only instance of objTargetOU in the script, I'm not sure if that is supposed to be in the Dim or not.
Line: 97
Char: 1
I hate VB with a passion. What is going on in this script exactly? Do you think that you are supposed to add it into the Dim manually, based on the name of the computer to move to, which the original code writer could not know, or have you put that somewhere in the text file? That would be my guess: you are meant to put it in the Dim yourself, with a value. What do you think? I am useless with VBScript. Trying to put DirectX knowledge into VBScript. Hmmm.
    Dell XPS 420
    Stock Dell 0TP406
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
I fixed it from your changes. I changed objTargetOU to objOU which was already declared and it works. Thanks for getting me passed the initial error, I would have pulled out the hairs on my chest trying to figure this one out...I'm already bald from other scripts. :-)
Well done! I did wonder whether it was something like this, but I did not have a good enough knowledge of the script to work it out, so I made some other suggestions :o Really glad that the problem has been fixed!
Richard
    Dell XPS 420
    Stock Dell 0TP406
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
