sd card gets semaphore time period expired error
lshead
I have a toshiba satelite 205 that has a SD slot. When I insert the card to transfer files I get the error: Semaphore time period has expired......
I read somewhere that if you lock the card that you can view the files, but you still cannot write to or from the disk. Does anyone know of a fix for this? Please help, I really need to use this disk.
rajinisback
Vista Pro
Hi Ishead!!
I went to toshiba's website and it gives instructions on how to use the card reader properly. I am wondering has the card reader ever worked for you before? How old is the laptop? Maybe it's under warrenty? Need some info to help you out. Thanks :)
Raj
lshead
The laptop is less than a year old. I successfully used the sd card with a usb card reader so I know the card is ok. I don't own the usb card reader (borrowed it from a friend) and I would like to be able to use the one built into the laptop. I have also gotten the same error when trying to use a usb thumb drive which I have two of and one of them works fine. The SD card was formatted when I used it in my kodak camera and the thumb drive was formatted when i used it to use files from another pc.
