SD Host Controller driver
antonianus
I found this old thread which relates exactly to the problem I am experiencing:
Ricoh SD Host Controller
I am able to install this , and get an updated driver off windows update.
HOWEVER, in device manager, I see this message with a yellow "!"
This device is not working properly because Windows cannot load the drivers
required for this device. (Code 31)
Click 'Check for solutions' to send data about this device to Microsoft and
to see if there is a solution available.
Any ideas how to fix this?
And there was this answer:
RE: Ricoh SD Host Controller
I figured out the problem. I have the Inspiron 6400, so your mileage may vary.
When I updated the device Ricoh SD Bus Host Adapter (under SD host adapters
in device manager) it messed up the Ricoh MMC Host Controller. So I went to
device manager and rolled back the latest version for the SD bus Host Adapter
(I am now using version 6.0.5384.4 dated 6/21/2006) and the problem was
fixed.
So the MMC controller device driver wasn't really the problem. It was just
the symptom.
Hope this helps.
"BoDEAN" wrote:
I have tried to do the same but my "driver roll back" link is faded and therefore not available.
Each time I uninstall and then install the driver it says the driver is up to date (version 6.1.7601.17514) but in Device Manager I still got the yellow triangle with the exclamation mark and needles to say, the SD card slot does not work.
Any further help with this will be most appreciated.
Thanks.
Lottiemansion
Please go to your PC's manufacturers website & download the original/ updated by them driver.
This will fix the problem.
If you need further help please provide the make, model & operating system information to get the links. OK?
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    BluRay & DVD Weiters
    40 Meg
antonianus
Hi again,
My computer's make is Advent and I cannot get any joy from anyone online regarding my problem. I have posted to the Advent's forum and again, no one seems to know or answer.
These are the details:
Advent fp9004
Windows 7 Home Premium 32bit.
If you can provide a link to a driver's update, will this install automatically after downloading, or do I need to force the installation and what is the recommended way?
Very grateful for all information.
Ton
Lottiemansion
Are we chasing a Windows seven problem or a Vista one? If it is Vista we can continue to assist. If not, please refer your challenge to the Seven forum: -
Windows 7 Forums
    40 Meg
