Search box fills up with apostrophes
PAB
Good morning,
I had a problem where when i clicked on the start button the start search box filled up with apostrophes, I had to use the backspace to get rid of them, and even then, on the odd occassion it would start filling up again with apostrophes. I only knew this was happening because I heard a continuous sound coming fro my computer and when I clicked on the start button the start search box was filling up with apostrophes again.
I had other problems as well so I clean installed Windows Vista Ultimate 32-bit.
I am still having the same problem even after the clean install.
I can't seem to find anything with regard to my specific problem on Google so I am asking here for any help of advice please.
Thanks in advance.
townsbg
~~тσωηsвg~~
Can you try another keyboard?
    Windows 7 Pro x64
    Mid 2010 iMac
    Quad core 3.2 Ghz Intel I3
    8 gb
    ATI Radeon HD 5670 512 mb ram
    1920x1080 and 1440x900
    1 TB
    Windows 2008 R2 Enterprise
    Compaq Presario SR5350F
    Pentium 2.0 gHZ Dual core E2160
    2 gb
    1440 x 900
    300 GB
PAB
Thanks for the reply townsbg.
Unfortunately it is on my laptop.
EDIT: I should have said that it is not a sticky key!
ilikefree
Gently pries off the apostrophe key and free it up as it sounds like a stuck key to me.
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
PAB
Thanks for the reply ilikefree,
I have checked the key by taking it off and found nothing unusual, the key was smooth and free in its operation. I then re-seated it back and started the laptop.
Still the same proble.
Thanks in advance.
EDIT: I have done all the updates avaiable in case it was something to do with an old version of something that I had insalled or was on the reinstall disc.
ilikefree
You can still use a USB keyboard with a laptop and it would help to track down the problem
    LENOVO 64734VM
    15 inch
    External Speakers
PAB
Unfortunately I don't have a USB keyboard at my disposal.
I have just checked that I have the latest driver installed for my keyboard and I have.
PAB
Well, I have been mucking around with this all day on and off, without success I might add.
If anyone has got any ideas they would be most welcome.
Thanks in advance.
townsbg
~~тσωηsвg~~
The general consensus seems to be the keyboard.
    Windows 7 Pro x64
    Mid 2010 iMac
    8 gb
    1 TB
    2 gb
    1440 x 900
    300 GB
wither 3
Does this happen immediately after you click on Search or after you selected For Files and Folders?
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
gonzo24
Similar problems were reported in this old thread and there seemed to be a variety of reasons.
Keys repeat uncontrollably
Perhaps you will see something that looks familiar? If you are hearing a noise that could suggest the computer is busy doing more than typing, so check task manager as one of the people in the thread did.
Does it only happen with the start button and search box? Or if you open a text file, word document etc. does it enter apostrophes there too?
    Dell
PAB
Thanks for the replies.
Sorry I haven't replied I have been away for a while.
gonzo24, that does sound very interesting and I will look at that shortly.
