Section 8
panais
Power User
I play Section 8
res 1920x1080 + Vsync+everything at MAXIMUM
The game has its own benchmark so i did it,and i received the below results...
And i will like to know,are good,medium,bad?
    Custom Built by me.
    Intel Core 2 Quad Q6600
    Gigabyte GA-X38-DS4
    KINGSTON HYPERX DDR2 4GB (2X2GB) PC6400 800MHZ DUAL CHANNEL KIT
    SAPPHIRE RADEON HD4890 OC 1GB GDDR5
    2/4/5.1/7.1-channel Realtek High Definition
    Samsung LE40A656F1 1080p 100Hz LCD HD TV 50,000:1
    1366x768 in Desktop,1920x1080p in gaming and video
    C:\WD VelociRaptor 150 GB,10,000 RPM
    D:\WESTERN DIGITAL WD15EADS 1.5TB CAVIAR GREEN SATA2 E:\WESTERN DIGITAL WD15EADS 1.5TB CAVIAR GREEN SATA2 No Raid.Copy Paste Is The Safest Way.
    Seasonic 700W 80plus
    A-Case Twin Engine BB
    3 thermaltake smart case fan II + 1 arctic cooling fan
    Wirelles Logitech Laser Mouse MX620
    Wireless Logitech LX710
    ADSL 4000plus
    F:\Sony high speed sata Dvd Rewriter
    KINGSTON HYPER X FAN
    +Cordless Rumblepad 2
dare978devil
Hi, I have never heard of the game Section 8, but I can certainly interpret benchmarks for you. Obviously, the higher frames per second, the better. However, once you go over 24 FPS, there is little need to worry about how high it can go. Movies in the cinema are filmed at 24 FPS and stored on DVDs in their original framerate. So to be "as fluid as a movie", you only need to sustain 24 FPS.
Your average is 39 : excellent
Min is 7 : could be a problem, but not if it was only for a second at the outset (some large bitmaps can take longer to load leading to a pause in the game). Anything less than 20 will start to stutter.
0.6% below 23 FPS : excellent, meaning you only have 1 in 200 frames dropping below 23 FPS. Your game should be very fluid.
Run the bench 3 times in succession, and then average the results, and you will have a good idea of what your gaming experience will be. I can already tell you that it should be very good.
DD.
archie123
I Tunes hates Me
as long as your happy playing the game at those settings it doesnt really matter , try playing online with those fps however and you'll get "owned" all over the map ;)
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
dare978devil
Hahaha, maybe, but again, it will make very little difference once you get above a certain FPS rate. For instance, someone getting 40 FPS won't be worse off than someone getting 60, your brain just doesn't have enough time to react. The advantage is theoretical.
But then again, he is running the game at max settings. Super-high res + vsync + all settings at max?? That means scaling a few of them back will easily bump him up to the 50+ range, and then it is all a matter of skill....
DD.
