Solved Selection tool in MS WORD is very inconsistant
danial
My selection tool in MS WORD is very inconsistant. If I select a word- as soon as I let up on the mouse- the selected colored area disappears. If I try to move a selection by dragging, the selection doesn't move (instead it selects the entire area that the selection tool moves over. I don't think I'm explaining this very well, but it really sucks.
What operating system are you using? Which version of MS Word?
Have you already tried restarting your computer?
    Dell Inspiron 1545
    Intel Core 2 Duo T6400 @ 2.00 GHz
    DELL - 27d90219 Phoenix ROM BIOS PLUS Version 1.10 A05
    Generic PnP Monitor (DPMS), 15.3" (34cm x 19cm)
    1366x768
    Internal 320 GB
    Portable 320 GB used for separate storage of media, plugged into USB port as needed.
    Single built in fan
    Built in
    Touchpad, + Logitech wireless mouse (USB)
    ~150 kilobytes/sec DL
    Usually have low HD free space left (<10 GB), often left on overnight. I really push its capabilities.
Thanks. I have resolved the problem- I got a new mouse and everything works fine. Who would have thought that a mouse could go bad? Tanks again
Thanks. I have resolved the problem- I got a new mouse and everything works fine. Who would have thought that a mouse could go bad? Thanks again
