Solved sending links in email
CalRed
Hi, I am still trying to find out how to send a link in an email without having to list the entire URL. Such as we can do on forums, etc. I am using Windows Mail with Windows Vista Home Premium 64, soon to upgrade to Windows 7.
Example—if I wanted to send a link to aol ionstead of having to list it this way,
www.aol.com, I should be able to list it as just aol and clicking on the link will go right there.
Any suggestions? I get emails like that all the time but can't figure out how to send one.....
Thanks in advance. CR$
mitchell
Ngai Tahu/Tau Iwi
Hello CalRed, You should be able to copy & paste the url from your browser and paste it to your cursor blink on the email you are sending.
There is also an option if you right click on the IE browser & select customise then add or remove commands you will find a send link by email option you can add to IE browser
As far as shortening the url i think you can right click on it and select Rename i think this works? you can only try
I hope this is of some help
    Hewlett Packard, compaq presario CQ60-305AU
    AMD Athlon QI-46 2.1 Ghz
    Wistron 303C
    2048 Mb DDR2 SD Ram
    NVidea GE Go Force 8200M G / 256Mb dedicated grapics memory
    MCP78S NVidea High definition
    15.6" High Definition Brightview Widescreen
    1336x768
    Toshiba MK2555GSX ATA
    Synaptics PS2/Touchpad
rhlhamlet
IT Guy
CalRed... It is very simple....
In Windows Mail, do the following (using your AOL as an example).
1. In the message body, type in AOL (or whatever you want the link to look like).
2. Highlight the text AOL (or whatever you typed).
3. Click on the "create hyperlink button".
4. Enter the URL there.
Now your message will show the link exactly as you typed it instead of the URL.
That my friend is basic email etiquette for even a new user.
    HP Pavilion Desktop
    Intel E2220 Dual 2.40 ghz 2400 mhz 2 core
    4gb Ram, 3.87gb physical memory, 7.95gb virtual meory
    Nvidea
    DSL 1.5
CalRed
rhlhamlet
Thanks very much. I felt as if it was simple but hadn't learned that one yet. I have always used Incredimail but when I recently bought my quad computer I decided to use Windows Mail.
I appreciate it and am glad to find this site.....
Regards, Cal R.
