sending mail failure! General MAPI failure [2]
dg8
Hi - I have a small program called Voicemail Recorder which will not work using Windows Vista sp2 - Outlook Express v6.
The program functions correctly - loading, recording but when I click on send it either freezes or tries to send but delivers a message "sending mail failure! General MAPI failure [2]"
Can anyone understand the problem and knows how to fix it. If anyone can help I would be grateful if your instructions to a solution is very simple to suit my limited knowledge.
Many thanks.
    Intel(R) Core(TM)2 Duo CPU E8400 @ 3,00GHz 300GHz
    2.00 GB
osholt
Magister mundi sum!
    Apple MacBook, 5,1
    Intel Core 2 Duo 2.4Ghz
    4GB DDR3
    Nvidia 9400m
    13.3" Apple MacBook LCD Screen + 22" HannsG DVI LCD + 21.5" Samsung USB Lapfit Monitor LD220
    1280x800 + 1920x1080 + 1920x1080
    SATA Internal 2.5" 500GB (305GB HFS+, 195GB NTFS)
    External USB 3.5" 1TB (HFS+)
    Aluminium Unibody
    Apple Magic Mouse
    Apple Late 2009 Wireless Keyboard (US)
    6.33Mb/s up. 0.36Mb/s down.
    Harman Kardon Soundsticks II Speakers
dg8
Thanks osholt but that was unsuccessful - sorry
Regards.
    2.00 GB
osholt
Magister mundi sum!
Regards.
I believe this may be a problem with your Email Client (Outlook, Thunderbird etc.).
Please can you specify your email client.
Oli
    Apple MacBook, 5,1
    4GB DDR3
    Nvidia 9400m
    Aluminium Unibody
    Apple Magic Mouse
dg8
Windows Internet explorer 8 - the email client is Windows Mail
Thanks Oli
    2.00 GB
