Solved Setting processor affinity made easy
Tiberius Jonez
While dual core and quad core processors are a great advance in processing power, many games in XP and Vista run better on a single core. Need for Speed Underground is one such game. In my search to find an easy way to set processor affinity, I found the easy method outlined below. This method is the best I've found and actually WORKS without having to make system-wide changes.
Enjoy!
Here's a tip I use for some games which have problems with dual core. It saves the trouble of [alt][tab] out of the game each time, and I find it easier than creating a batch file. You may have already seen this, if so, the short answer is written in red at the bottom of this post.....
Affinity and priority can be permanently added to an application's shortcut so that you don't have to change it every time you run it.
To begin, create a shortcut to the game on the desktop.
Right click the shortcut and select properties. In the "shortcut" tab, find the line for "target". Copy this in front of the target: C:\Windows\System32\cmd.exe /C START "Need for Speed Undercover" /high /affinity 1. Now, NFS Underground will automatically run in high priority on Core 0.
Here's an example for the game Tombraider Legend which also balks at dual core processing.
The target line originally looks like this:
  • "C:\Program Files (x86)\Tomb Raider - Legend\trl.exe"
    So I change it to this:
  • C:\Windows\System32\cmd.exe /C START "Tomb Raider" /high /affinity 1 "C:\Program Files (x86)\Tomb Raider - Legend\trl.exe"
The affinity can be set to any CPU core by changing the number to the corresponding hex value.
1st core = 1
2nd core = 2
3rd core = 4
4th core = 8
5th core = 10 ( hexadecimal 16 )
6th core = 20 ( hexadecimal 32 )
The priority can have any value of either: low, normal, high, realtime, abovenormal, belownormal.
So to run on only the 4th core at high priority you would put:
  • C:\Windows\System32\cmd.exe /C START "Tomb Raider" /high /affinity 8 "C:\Program Files (x86)\Tomb Raider - Legend\trl.exe"
    or to run on the 2nd AND 3rd cores with priority realtime you would put:
  • C:\Windows\System32\cmd.exe /C START "Tomb Raider" /realtime /affinity 6 "C:\Program Files (x86)\Tomb Raider - Legend\trl.exe" (Since 2+4=6)
Sometimes if the game needs to be run as administrator, then you get an error from not starting in the correct folder. Then also add:
/d "<directory>"
The end result being:
C:\Windows\System32\cmd.exe /C START "Tomb Raider" /d "C:\Program Files (x86)\Tomb Raider - Legend" /high /affinity 1 "C:\Program Files (x86)\Tomb Raider - Legend\trl.exe"
Finally, you just need to change the icon since this will set it to the CMD icon. From the same window, click "change icon" then browse to the location of the exe.
And if you need to run as admin, click the advanced button and check the box"run as administrator"
MadBull
Thank you so much! This works great on old games like Raganarok and Age of Empires. :D
    3.6 Ghz AMD Phenom II X3 720 BE
    Gigabyte MA790X-UDP4
    4GB OCZ DDR2 800Mhz
    Asus EAH4850 512MB
    Samsung SyncMaster 2253BW
    C: 320GB Seagate SATA
    D: 720GB Seagate SATA
MrNeeds
PC Geek
Enjoy!
1st core = 1
2nd core = 2
3rd core = 4
4th core = 8
/d "<directory>"
or if you got a Nvidia Graphics card, you could just turn threaded optimization off.
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Samsung 7200rpm 250Gb SATA,
    Samsung 7200rpm 750Gb SATA,
    WD 7200rpm 1TB SCSI SATA.
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
hrabby
FIFA 10 by default runs on one core. Need to use at least 2 cores for better performance. Used the following line on the shortcut target box:
D:\Windows\System32\cmd.exe /C START "FIFA 10" /d "D:\Program Files/EA Sports/FIFA 10" /high /affinity 6 "D:\Program Files\EA Sports\FIFA 10\FIFA10.exe"
Also tried:
D:\Windows\System32\cmd.exe /C START "FIFA 10" /high /affinity 6 "D:\Program Files\EA Sports\FIFA 10\FIFA10.exe"
Game starts but still uses only the first core. I can see priority goes up to high but no core change. What am I doing wrong?
p.s. System root is D: and game is also on D:.
