Solved Setup Hotmail in Outlook
Patonb
Odd problem, hopen someones been here already
With the sad demise of WLM and messanger I now need to setup my Outlook '03 to get my Hotmail email.
I go add a new account, select Hotmail, and try me email... Outlook can't find the server.
Looking around, MS has made a dandy helper program fo0r the switch over, so i d/l it and install..., It doesn't do what their site says it should so I'm, now stuck.
I'm a hotmail address but need the new Outlook.com server info.
Please help me...
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
Hi
Try this:
Make sure POP3 is selected under Incoming e-mail server type:.
Type "pop3.live.com" under Incoming mail server:.
Enter "smtp.live.com" under Outgoing e-mail server (SMTP) name:.
Make sure Outgoing server requires authentication is checked.
Click Next.
Type your full Windows Live Hotmail email address under E-mail username:.
Enter your emails password under Password:.
Click Next.
Make sure “Do not download my e-mail at this time” is checked.
Click Finish.
Highlight the new account in the list.
Click Properties.
Go to the Advanced tab.
Make sure “This server requires a secure connection (SSL)” is checked under both Outgoing mail (SMTP): and Incoming mail (POP3):.
Type "587" under Outgoing server (SMTP):.
If the number under Incoming server (POP3): is not "995", enter "995" there.
Click OK.
Click Close.
This works for configuring to Windows Mail so the settings should work for Outlook. No guarantee as i haven't tried it but worth a try!
Let me know how it goes!
That worked
Thanks
