Severe Underperformance 9600
NOTE: Que also listed in Gaming forum
Hello!
I have very poor AMD Phenom 9600 benchmarks:
WinRAR = 454 w/TLB fix diabled Avg scores for my system 1,100
Call Juarez = 30 FPS Avg score = 45
Dont know whats wrong. Could it be a dead core? How can I check?
1) My WinRAR score with the TLB fix enabled is a sickening 80!!! vs 454 disabled. So I am certain that the fix was disabled at my score of 454.
2)Regarding number of active cores:
a) When I run task manager I see only ONE window for CPU in performance.
b) Running CPU-Z V1.49 shows ONE Processor ONE Core
c) CrystalCUPID V 4.15 shows only ONE of One cores (Code name Agena?) I should see 1/FOUR
d) In Vista Sidebar using mCPU Gadget: Shows Four cores HOWEVER
only ONE ever displays activity. I tested it by really loading up applications and Never saw activity of the other three cores!!!
I think I have a REAL Problem here. help
My Setup:
OS : Windows Vista Home Premium X-64 SP1
CPU Name : AMD Phenom X4 (Agena)9600 Quad-Core
Platform : Socket AM2/AM2+ Physical Core : 4
Clock : 2300.00 MHz
L1 I-Cache : 64 KB
L1 D-Cache : 64 KB
L2 Cache : 512 KB [Full:2300.14 MHz]
L3 Cache : 2048 KB
Memory : 3327 MB
North Bridge : 780G South Bridge : SB700
Video Chip :ATI Radeon HD 3870
BIOS Vendor : American Megatrends Inc.
BIOS Version : GATEWA - 20080218
BIOS Date : 02/18/2008
SM BIOS Caption : 7B3G1P04
SM BIOS Version : 2.5
Mother Vendor : Gateway
Mother Product : Foxconn
Mother Version : Piece of Junk
System Vendor : Gateway
System Model : GT5676
BIOS ROM Size : 1024 KB
    Gateway GT5676
    AMD Phenom Quadcore 9600 at 2.3GHz
    Stock (Foxconn Bengal RS780)
    4 MB DIMM
    ATI Radeon HD3870 by VisionTek
    Realtek Integrated HD Audio - Stock
    ViewSonic VX-910, 19"
    1280 X 1024
    Two 320GB, 7200rpm, SATA II
    Corsair TX650W
    Micro ATX, Gateway
    Stock
    Stock
    Stock
    3 MB
lordbob75
Lord of Bobs
Vista Pro
Since you have a quad core try using Real Temp. It works for the 45nm CPUs, like that one is (I think) If it is 65, then use speed fan. Let us know what that one registers.
Also, CPU-Z is a great utility for reading your stats, download and run that, and it should show your exact specs on your CPU.
If those are showing wierd readings, then you may indeed have a bad CPU. Though it could be a bad mobo. To check this, you could try replacing the CPU with an older one you know works (preferable a 2 or 4 core), and check the readings. If it is similar, then the mobo could be to blaime. If they are correct, then a bad CPU is more likely.
Let us know what you find!
~Lordbob
    ASUS P5QC
    2x2GB
    NVidia GeForce 9500GT 1Gb
    Mobo
    Samsung SyncMaster 206bw
    Samsung SP2514N ATA 250Gb 7200RPM
    Samsung [Model] 1Tb 7200RPM SATA2
    Razer Lachesis
    Razer Tarantula
    not fast enough
lordbob75
Lord of Bobs
Vista Pro
Oops, I didn't completely read... *shame on me!*
So CPU-Z had the same thing. Check Real Temp though for sure!
~Lordbob
EDIT: On CPU-Z, does it show the correct processor name? i.e. Agena 9600? If not, then the sensors could be off, not just the CPU...
Also, what does the BIOS say about the CPU?
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
MrNeeds
PC Geek
~Lordbob
you obviously been drinking bob lol
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Samsung 7200rpm 250Gb SATA,
    Samsung 7200rpm 750Gb SATA,
    WD 7200rpm 1TB SCSI SATA.
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
Everlong
To xor or not to xor
    Intel Core 2 Quad Q9550
    XFX MB-750I-72P9 NF750i
    4096MB Corsair XMS2 PC-5400
    ASUS Nvidia Geforce GTX470
    ASUS Xonar DX
    1920x1080 & 1680x1050
    Logitech G11 Keyboard
    100Mbps
Thanks Again. RealTemp is for Intel I have an AMD cpu. I ran Speed Fan. The the results are attached. Here are the readings:
Temp1: 43C
Temp 2 42C
Temp 3 -128C
Core 43C
Hmmmm , not very consistent are they.
John
    Gateway GT5676
    4 MB DIMM
    1280 X 1024
    Corsair TX650W
    Micro ATX, Gateway
    Stock
    Stock
    Stock
    3 MB
lordbob75
Lord of Bobs
Vista Pro
If your chip is a 45nm chip, then speed fan wont work. You need the correct ap for a 45nm chip.
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
#8
~Lordbob
Thank You Lord,
Foxconn considers the MB a 3rd party item and have no plans for support. I'll never buy retail again. Thanks, John
NEW INFO
I have run a multitude of programs that indicate problems. The attached image displays results from:
1) SpeedFan (Core 3 at -128C)
2) WinRAR bechmark score(Ludicrous!!! 80??)
3) Vista sidebar Gadget Multi-Meter Q (Tiny meter in center of pic Shows ONE core Max''d. I was Never able to see Any Activity by Any of the other cores)
4) CPUz which shows at bottom Selection is Greyed Out at Processor 1, fine, I have only 1 BUT it also shows only ONE core.
5) Under SYSINFO/Processor shows: AMD Phenom 9600 Quad-Core Processor, 2300Mhz, 1 Core(s), 1 Logical processor
I also ran a prog to Change the Number of Processors (& Cores in Duo's & Quads) in Vista Boot Up. Using msconfig I got to System/Config/Boot/Advanced where I should be able to select the number of Processors or Cores, it is Grayed Out at One and I Can Not check the # of Processors.
However, Both Device Manager and BIOS see Quad-Core 9600.
Gateway tells me to re-install Vista.
I Believe I have a Bum Quad-Core.
Thank You, John
ps Customer Review of 9600 on NewEgg:
Other Thoughts: I think New Egg should take 64 Bit supported off of the spec screen, there are a lot of posts on other websites about this processor and 64 bit Vista not working. Something about the way the 3rd core doesn't sync when using Vista 64 bit os. It's pretty technical but amounts to... Don't buy this processor if your using 64 bit Vista or want to use 64 bit Vista and if you want to use all 8 gb of ram you have to use 64 bit Vista.
    Gateway GT5676
    4 MB DIMM
    1280 X 1024
    Corsair TX650W
    Micro ATX, Gateway
    Stock
    Stock
    Stock
    3 MB
lordbob75
Lord of Bobs
Vista Pro
Ummm... What exactly is your background there? You may want to consider blocking it out....
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
#10
Yikes!! Done THANK You, John
    Gateway GT5676
    4 MB DIMM
    1280 X 1024
    Corsair TX650W
    Micro ATX, Gateway
    Stock
    Stock
    Stock
    3 MB
lordbob75
Lord of Bobs
Vista Pro
Lol your welcome.
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
#12
Sorry you got a bad chip, but to suggest it's an inherent problem with the processor's designed interaction w/ the OS seems unfounded. You came across a few people who've had a similar problem out of how many processors shipped? If it was really an issue with the processor it should be the norm not the exception.
BTW mine is running great.
    AMD Phenom x4 9600 Agena
    Asus M3A-H/HDMI
    8GB OCZ Fatal1ty PC2-6400
    Powercolor Radeon HD4830
    HP W2408h, Gateway VX1100
    1920x1200, 1600x1200
    Maxtor 200GB IDE (x2)
    WD Caviar SE16 640GB SATA (x2)
    CoolerMaster eXtreme Power Plus 500w
    CoolerMaster ATCS 210
    MS Wireless Mouse for Bluetooth
    MS Wireless Keyboard for Bluetooth
