SFC Problems
xBlackheart
I recently ran SFC and it found issues but couldn't repair some of them. This is a strange issue I've been having lately. I don't normally have issues with it being unable to repair corrupted files. It has happened once, but I did a system recovery to fix it. I thought I would try that again, but after the 16 hour process, I ran SFC and it found corrupted files that it couldn't repair.
After doing as much referencing as I could. I couldn't figure out what the issue was and I couldn't find the problem when I check the CBS log. I wanted to include it as an attachment for anyone who might be able to help me figure out what the issue is, but the CBS log is 16MB and I couldn't attach it.
Anyone can help me read this CBS log so I can fix SFC?
Also, what exactly do you think might be the cause of the corrupted windows files? Is it hackers? Is my computer in security danger by having corrupted windows files? I ask because I'm not sure and I'm worried about it. It sounds like a serious issue.
Also, I don't have a Windows Vista installation or recovery disk. I bought the computer at best Buy nearly seven years ago. I bought it brand new, but it didn't come with one. Instead, there is just a recovery partition that allows me to restore it to factory condition if I need to.
    Compaq SR5310F
    Intel Pentium dual-core E2140
    IPILP-LC (Lancaster8)
    1GB DDR2 DIMM (Two Sticks)
    PNY Nvidia GeForce 9500GT
Hello xBlackheart, and welcome to Vista Forums.
If you like, you could use the yellow TIP box in the tutorial below to generate a sfcdetails.txt file, then upload that file here. I'll be happy to take a look at it to see and tell you what files SFC was not able to repair. :)
http://www.vistax64.com/tutorials/66978-system-files-sfc-command.html
I tried to do it on both computers I'm experiencing the problems with. One of them (the laptop) generated a blank (0 byte) sfcdetails.txt file. The desktop reported an errord "FINDSTR: Cannot Open I
FINDSTR: Cannot Open A\Desktop\sfcdetails.txt"
The big problem I am having is this Startup Repair loop. It just started happening out of nowhere on both of my systems. I figured it might be the showings of a cyber attack. The laptop is giving me the BSOD, then proceeds to Startup Recovery, then repairs" the problem until I shut it down, of which the cycle repeats itself.
For the desktop, it's just the Startup Repair loop. I even did a full system recovery using the recovery partition and after all the windows updates (a long process) and no other problems, it just started happening again.
I looked into a possible FixParitionTable error, but I don't have a Vista disk to preform a BootRec. As for the laptop, I was able to create a Disk using an ISO I got from a licensed vendor. I just haven't put it to use yet. I was hoping there might be an easier way to solve my issues. Any suggestions?
    Compaq SR5310F
Ok. Go ahead and place the CBS log in a ZIP file, and you should be able to upload it then. :)
Okay here is the CBS from the Desktop. This is the one I just preformed a two-day recovery process on, only to have it give me the Startup Repair issue and tell me SFC couldn't repair some problems at the end of it all.
    Compaq SR5310F
I'm getting a different kind of loop. As I explained my laptop gives me a BSOD error screen on startup after everytime I shut it down. It goes through the Startup Repair, then prompts me to fix the issue with system recover, then boots up. It keeps doing this over and over. For my desktop, it's the same thing, only without the BSOD. Everytime I shut it down, when I go to start it up again, it runs me through Startup Repair (even after a full system recovery). There is some kind of root problem I guess, but it doesn't make sense because my laptop is nearly brand-new. I figured it was the work of cyber attackers, so I've been trying to get those windows files fixed. I figured that would be a good start to getting things secured.
    Compaq SR5310F
Totally amazing, LOL.
Here is the requested information!~
    Compaq SR5310F
You have given us only one report, which at best gives little clues to the cause of your problem. It usually takes at least several reports of BSODs to suggest a solution to your problem. The clue given by your report was a driver. Unfortunately, it was a Microsoft Driver and is not the true cause but merely a scapegoat.
It is your choice, I can use the report and my experience to suggest tests or we can wait until you get a few more reports. If you want to take a chance, lets start with a potential driver problem. Take the Driver Verifier test.
Driver Verifier
I'd suggest that you firstbackup your data and then make sure you've got access to another computer soyou can contact us if problems arise. Then make a System Restore point (so youcan restore the system using the Vista/Windows 7 Startup Repair feature).
In Windows 7 you can make a Startup Repair disk by going to Start....AllPrograms...Maintenance...Create a System Repair Disc - with Windows Vistayou'll have to use your installation disk or the "Repair your computer"option at the top of the Safe Mode menu .
Then, here's the procedure:
- Go to Start and type in "verifier" (without the quotes) and press Enter
- Select "Create custom settings (for code developers)" and click"Next"
- Select "Select individual settings from a full list" and click"Next"
- Select everything EXCEPT FOR "Low Resource Simulation" and click"Next"
- Select "Select driver names from a list" and click "Next"
Then select all drivers NOT provided by Microsoft and click "Next"
- Select "Finish" on the next page.
Reboot the system and wait for it to crash to the Blue Screen. Continue to useyour system normally, and if you know what causes the crash, do thatrepeatedly. The objective here is to get the system to crash because
Driver Verifier isstressing the drivers out. If it doesn't crash for you, then let it run for atleast 36 hours of continuous operation (an estimate on my part).
If you can't get into Windows because it crashes too soon, try it in Safe Mode.
If you can't get into Safe Mode, try using System Restore from yourinstallation DVD to set the system back to the previous restore point that youcreated.
DriverVerifier - Enable and Disable
I ran the program as suggested. What exactly do you mean by, "more reports"?
Do you mean you need me to run the SF Diag Tool several times?
I'm going to attempt what you've suggested and post the results ASAP.
    Compaq SR5310F
Use your computer, as you normally due, but with the verifer activated. After about
36 hours send me your BSOD reports, in the same way you sent them the first time.
If you do not get any BSODs, we know it is probably not a driver problem and then we can move on to other tests.
Just did as you requested. There was a clean start-up with no BSOD. Given the information you've suggested, I would say this must mean it is, in fact, a windows driver that's corrupted (also suggests the SFC issue). However, I'm still unsure as to how this came about. Was this due to a cyber attack? I've done the best I can to keep my computer as secure as possible. I've disabled all the most vulnerable services. I use double firewalls, Comodo Internet Security + Windows Firewall w/ Advanced Security blocking inbound and outbound that don't match a rule. Is there something I could be using wrong that allows cyber attackers to best my defenses?
I've done a few runs at the ShieldsUp test. My ports are closed and not all of them are stealth. When I looked into this issue I came across a few contradictions. The first one is that Windows Firewall (Vista and Up) is supposed to have automatic drop-off and stealth mode. The second is that Comodo Firewall is supposed to be making all my ports stealth VIA their easy one-touch Stealth Ports wizard. Any suggestions as to how I can get these ports stealth like they're supposed to be, or tips on what I might have done wrong to stealth them? Normally I use a proxy, but I feel that should be unnecessary if you've configured your firewall and services properly.
    Compaq SR5310F
No one can tell you what caused the problem. Many times it is malware, but you said that your scans were negative.
Another possiblity is a hard drive with errors, you may want to make a chkdsk to verify that possiblity. Check the first and second box to check and repair all errors.
http://www.vistax64.com/tutorials/67612-check-disk-chkdsk.html
Still another possiblity is that an older driver is in conflict with other software. There are may possibilites and no one can tell you the cause, but only hope for a solution.
It is suggested that the Verifier be used for 36 hours. If your problem is only during start up, you may want to turn the computer off after each use, so that you can boot again. At this juncture, we actually want you to BSOD.
I have helped many with BSODs and may are caused by the Anti Virus used and/or firewalls. It is suggested that only one firewall and one Anti Virus be used and more than one can cause problems including BSODs.
After you use the computer for 36 hours, as suggested, I will look at the additional BSODs. If you do not get any others, just use the computer normally and post in this thread any additional BSODs. It is very possible that it was a one shot deal that will not happen again,too.
Well, just got done trying out that Verifier on the desktop. It shut down before start-up and then Startup Repair kicked in as expected. I'm currently waiting for System Restore to finish and return me to where I started. I've run a lot of scans on the desktop, trying to get to the bottom of the issue. One of the error messages I got was FixPartitionTable, but I can't do that without a Vista disk correct? If so, I'm totally SOL. I don't have one. I though that a System Recovery would fix this issue, but it doesn't seem to have. Should it have though? I'm not sure. It's an old Compaq but it has a D:\ Virtual Drive with a recovery partition on it. I don't understand why this hasn't fixed the problem. I guess the hard drive itself could finally be going down on me. All the scans I've conducted so far point toward a hard drive issue, but as I said, only one that should be repairable (PartitionTable, fixable with bootrec). I just need to figure out a way to run Bootrec without a Vista disk right? Or find a way to burn myself a Vista copy legally.
    Compaq SR5310F
Try the chkdsk as previously suggested.
I finally just rage-quit on my laptop and decided to do a clean install. I'll let you know any details as they arise. As for the desktop, I did as requested and it shut-down before start-up, returning me to the Startup Recovery from which I've returned to here.
Here is the information for my desktop. I couldn't do a Host scan because it gave me an error message. Please let me know if that's essential or not.
    Compaq SR5310F
Dont know if this is related to your current problem or not, but your drivers are more than very old. Make sure that your Windows Updater is set to install automatically.
Code:
Module Name  Display Name           Driver Type   Link Date
ACPI         Microsoft ACPI Driver  Kernel        4/11/2009 12:19:03 AM
adp94xx      adp94xx                Kernel        9/5/2006 3:55:58 PM
adpahci      adpahci                Kernel        9/5/2006 3:51:11 PM
adpu160m     adpu160m               Kernel        10/25/2005 1:00:45 AM
adpu320      adpu320                Kernel        3/13/2006 9:47:51 PM
AFD          Ancilliary Function Dr Kernel        4/21/2011 9:58:25 AM
agp440       Intel AGP Bus Filter   Kernel        11/2/2006 4:35:06 AM
aic78xx      aic78xx                Kernel        4/11/2006 8:20:11 PM
aliide       aliide                 Kernel        11/2/2006 4:51:35 AM
amdagp       AMD AGP Bus Filter Dri Kernel        11/2/2006 4:35:06 AM
amdide       amdide                 Kernel        11/2/2006 4:51:35 AM
AmdK7        AMD K7 Processor Drive Kernel        11/2/2006 4:30:18 AM
AmdK8        AMD K8 Processor Drive Kernel        11/2/2006 4:30:18 AM
arc          arc                    Kernel        8/21/2006 7:08:39 PM
arcsas       arcsas                 Kernel        8/14/2006 6:02:44 PM
AsyncMac     RAS Asynchronous Media Kernel        1/19/2008 12:56:29 AM
atapi        IDE Channel            Kernel        4/11/2009 12:39:09 AM
Beep         Beep                   Kernel        1/19/2008 12:49:10 AM
bowser       Bowser                 File System   2/22/2011 8:23:54 AM
BrFiltLo     Brother USB Mass-Stora Kernel        8/6/2006 5:33:45 PM
BrFiltUp     Brother USB Mass-Stora Kernel        8/6/2006 5:33:45 PM
Brserid      Brother MFC Serial Por Kernel        8/6/2006 5:33:50 PM
BrSerWdm     Brother WDM Serial dri Kernel        8/6/2006 5:33:44 PM
BrUsbMdm     Brother MFC USB Fax On Kernel        8/6/2006 5:33:43 PM
BrUsbSer     Brother MFC USB Serial Kernel        8/9/2006 8:02:02 AM
BTHMODEM     Bluetooth Serial Commu Kernel        11/2/2006 4:55:22 AM
cdfs         CD/DVD File System Rea File System   1/19/2008 12:28:02 AM
cdrom        CD-ROM Driver          Kernel        4/11/2009 12:39:17 AM
circlass     Consumer IR Devices    Kernel        11/2/2006 4:55:08 AM
CLFS         Common Log (CLFS)      Kernel        4/11/2009 12:13:51 AM
cmdGuard     COMODO Internet Securi File System   3/11/2012 4:41:53 PM
cmdHlp       COMODO Internet Securi Kernel        3/11/2012 4:41:11 PM
cmdide       cmdide                 Kernel        11/2/2006 4:51:35 AM
Compbatt     Microsoft Composite Ba Kernel        11/2/2006 4:35:03 AM
crcdisk      Crcdisk Filter Driver  Kernel        11/2/2006 4:52:27 AM
Crusoe       Transmeta Crusoe Proce Kernel        11/2/2006 4:30:18 AM
DfsC         DFS Namespace Client D File System   4/14/2011 10:59:03 AM
disk         Disk Driver            Kernel        4/11/2009 12:39:14 AM
drmkaud      Microsoft Kernel DRM A Kernel        1/19/2008 12:53:16 AM
DXGKrnl      LDDM Graphics Subsyste Kernel        1/20/2011 8:50:57 AM
E1G60        Intel(R) PRO/1000 NDIS Kernel        8/3/2006 5:30:03 PM
Ecache       ReadyBoost Caching Dri Kernel        4/11/2009 12:40:12 AM
elxstor      elxstor                Kernel        9/14/2006 8:40:28 PM
exfat        exFAT File System Driv File System   4/11/2009 12:13:53 AM
fastfat      FAT12/16/32 File Syste File System   4/11/2009 12:13:52 AM
fdc          Floppy Disk Controller Kernel        11/2/2006 4:51:33 AM
FileInfo     File Information FS Mi File System   1/19/2008 12:34:27 AM
Filetrace    FileTrace              File System   1/19/2008 12:30:23 AM
flpydisk     Floppy Disk Driver     Kernel        11/2/2006 4:51:32 AM
FltMgr       FltMgr                 File System   4/11/2009 12:13:59 AM
gagp30kx     Microsoft Generic AGPv Kernel        11/2/2006 4:35:07 AM
HdAudAddServ Microsoft 1.1 UAA Func Kernel        11/1/2006 9:43:11 PM
HDAudBus     Microsoft UAA Bus Driv Kernel        4/11/2009 12:42:41 AM
HidBth       Microsoft Bluetooth HI Kernel        11/2/2006 4:55:21 AM
HidIr        Microsoft Infrared HID Kernel        11/2/2006 4:55:01 AM
HidUsb       Microsoft HID Class Dr Kernel        4/11/2009 12:42:48 AM
HpCISSs      HpCISSs                Kernel        7/31/2006 7:29:22 PM
HSF_DP       HSF_DP                 Kernel        12/7/2006 6:03:27 PM
HSXHWBS2     HSXHWBS2               Kernel        12/7/2006 6:04:39 PM
HTTP         HTTP                   Kernel        2/20/2010 3:53:31 PM
i2omp        i2omp                  Kernel        11/2/2006 4:51:36 AM
i8042prt     i8042 Keyboard and PS/ Kernel        1/19/2008 12:49:17 AM
iaStorV      Intel RAID Controller  Kernel        10/6/2006 2:01:40 PM
iirsp        iirsp                  Kernel        12/13/2005 4:48:01 PM
inspect      COMODO Internet Securi Kernel        3/11/2012 4:41:00 PM
IntcAzAudAdd Service for Realtek HD Kernel        2/11/2009 7:38:05 AM
intelide     intelide               Kernel        1/19/2008 12:49:42 AM
intelppm     Intel Processor Driver Kernel        1/19/2008 12:27:20 AM
IpFilterDriv IP Traffic Filter Driv Kernel        1/19/2008 12:56:23 AM
IPMIDRV      IPMIDRV                Kernel        11/2/2006 4:42:03 AM
IPNAT        IP Network Address Tra Kernel        1/19/2008 12:56:28 AM
IRENUM       IR Bus Enumerator      Kernel        1/19/2008 12:55:19 AM
isapnp       PnP ISA/EISA Bus Drive Kernel        11/2/2006 4:35:11 AM
iScsiPrt     iScsiPort Driver       Kernel        4/11/2009 12:40:07 AM
iteatapi     ITEATAPI_Service_Insta Kernel        8/10/2006 10:11:47 PM
iteraid      ITERAID_Service_Instal Kernel        8/10/2006 9:38:19 PM
kbdclass     Keyboard Class Driver  Kernel        1/19/2008 12:49:14 AM
kbdhid       Keyboard HID Driver    Kernel        4/11/2009 12:38:40 AM
KSecDD       KSecDD                 Kernel        6/1/2012 5:56:07 PM
lltdio       Link-Layer Topology Di Kernel        1/19/2008 12:55:03 AM
LSI_FC       LSI_FC                 Kernel        9/6/2006 1:31:15 PM
LSI_SAS      LSI_SAS                Kernel        9/6/2006 1:31:38 PM
LSI_SCSI     LSI_SCSI               Kernel        9/6/2006 1:32:01 PM
luafv        UAC File Virtualizatio File System   1/19/2008 12:30:35 AM
mdmxsdk      mdmxsdk                Kernel        6/19/2006 5:26:59 PM
megasas      megasas                Kernel        8/29/2006 12:47:25 AM
Modem        Modem                  Kernel        1/19/2008 12:57:16 AM
monitor      Microsoft Monitor Clas Kernel        1/19/2008 12:52:19 AM
mouclass     Mouse Class Driver     Kernel        1/19/2008 12:49:14 AM
mouhid       Mouse HID Driver       Kernel        1/19/2008 12:49:16 AM
MountMgr     Mount Point Manager    Kernel        1/19/2008 12:49:13 AM
mpio         Microsoft Multi-Path B Kernel        11/2/2006 4:52:37 AM
mpsdrv       Windows Firewall Autho Kernel        1/19/2008 12:54:45 AM
Mraid35x     Mraid35x               Kernel        9/7/2006 9:21:32 PM
MRxDAV       WebDav Client Redirect File System   4/11/2009 12:14:39 AM
mrxsmb       SMB MiniRedirector Wra File System   4/29/2011 9:24:39 AM
mrxsmb10     SMB 1.x MiniRedirector File System   7/6/2011 11:31:46 AM
mrxsmb20     SMB 2.0 MiniRedirector File System   4/29/2011 9:24:41 AM
msahci       msahci                 Kernel        11/2/2006 4:51:36 AM
msdsm        Microsoft Multi-Path D Kernel        11/2/2006 4:52:40 AM
Msfs         Msfs                   File System   1/19/2008 12:28:08 AM
msisadrv     ISA/EISA Class Driver  Kernel        1/19/2008 12:32:51 AM
MSKSSRV      Microsoft Streaming Se Kernel        1/19/2008 12:49:19 AM
MSPCLOCK     Microsoft Streaming Cl Kernel        1/19/2008 12:49:18 AM
MSPQM        Microsoft Streaming Qu Kernel        1/19/2008 12:49:18 AM
MsRPC        MsRPC                  Kernel        4/11/2009 12:37:32 AM
mssmbios     Microsoft System Manag Kernel        1/19/2008 12:32:55 AM
MSTEE        Microsoft Streaming Te Kernel        1/19/2008 12:49:18 AM
Mup          Mup                    File System   4/11/2009 12:14:12 AM
NativeWifiP  NativeWiFi Filter      Kernel        4/11/2009 12:43:27 AM
NDIS         NDIS System Driver     Kernel        4/11/2009 12:45:52 AM
NdisTapi     Remote Access NDIS TAP Kernel        1/19/2008 12:56:24 AM
Ndisuio      NDIS Usermode I/O Prot Kernel        1/19/2008 12:55:40 AM
NdisWan      Remote Access NDIS WAN Kernel        4/11/2009 12:46:31 AM
NDProxy      NDIS Proxy             Kernel        1/19/2008 12:56:28 AM
NetBIOS      NetBIOS Interface      File System   1/19/2008 12:55:45 AM
netbt        NETBT                  Kernel        4/11/2009 12:45:35 AM
nfrd960      nfrd960                Kernel        6/6/2006 5:12:15 PM
Npfs         Npfs                   File System   4/11/2009 12:14:01 AM
nsiproxy     NSI proxy service      Kernel        1/19/2008 12:55:50 AM
Ntfs         Ntfs                   File System   4/11/2009 12:14:34 AM
ntrigdigi    N-trig HID Tablet Driv Kernel        8/14/2006 3:29:13 PM
Null         Null                   Kernel        1/19/2008 12:49:12 AM
nvlddmkm     nvlddmkm               Kernel        5/15/2012 3:34:51 AM
nvraid       nvraid                 Kernel        10/3/2006 8:25:15 PM
nvstor       nvstor                 Kernel        10/3/2006 8:25:15 PM
nv_agp       NVIDIA nForce AGP Bus  Kernel        11/2/2006 4:35:08 AM
ohci1394     NEC FireWarden OHCI Co Kernel        11/2/2006 4:55:16 AM
Parport      Parallel port driver   Kernel        11/2/2006 4:51:29 AM
partmgr      Partition Manager      Kernel        3/20/2012 1:18:52 PM
Parvdm       Parvdm                 Kernel        11/2/2006 4:51:23 AM
pci          PCI Bus Driver         Kernel        4/11/2009 12:19:16 AM
pciide       pciide                 Kernel        11/2/2006 4:51:35 AM
pcmcia       pcmcia                 Kernel        11/2/2006 4:35:13 AM
PEAUTH       PEAUTH                 Kernel        10/23/2006 4:55:32 AM
PptpMiniport WAN Miniport (PPTP)    Kernel        1/19/2008 12:56:34 AM
Processor    Processor Driver       Kernel        11/2/2006 4:30:18 AM
PSched       QoS Packet Scheduler   Kernel        4/11/2009 12:45:51 AM
ql2300       QLogic Fibre Channel M Kernel        4/12/2006 8:33:54 PM
ql40xx       QLogic iSCSI Miniport  Kernel        7/6/2006 3:38:16 PM
QWAVEdrv     QWAVE driver           Kernel        1/19/2008 12:56:07 AM
RasAcd       Remote Access Auto Con Kernel        1/19/2008 12:56:31 AM
Rasl2tp      WAN Miniport (L2TP)    Kernel        1/19/2008 12:56:33 AM
RasPppoe     Remote Access PPPOE Dr Kernel        4/11/2009 12:46:30 AM
RasSstp      WAN Miniport (SSTP)    Kernel        4/11/2009 12:46:40 AM
rdbss        Redirected Buffering S File System   4/11/2009 12:14:26 AM
RDPCDD       RDPCDD                 Kernel        1/19/2008 1:01:08 AM
rdpdr        Terminal Server Device Kernel        11/2/2006 5:02:58 AM
RDPENCDD     RDP Encoder Mirror Dri Kernel        1/19/2008 1:01:09 AM
RDPWD        RDP Winstation Driver  Kernel        5/1/2012 10:03:45 AM
rspndr       Link-Layer Topology Di Kernel        1/19/2008 12:55:03 AM
RTL8169      Realtek 8169 NT Driver Kernel        8/2/2007 10:44:57 PM
sbp2port     SBP-2 Transport/Protoc Kernel        11/2/2006 4:51:44 AM
secdrv       Security Driver        Kernel        9/13/2006 9:18:32 AM
Serenum      Serenum Filter Driver  Kernel        11/2/2006 4:51:25 AM
Serial       Serial Port Driver     Kernel        11/2/2006 4:51:29 AM
sermouse     Serial Mouse Driver    Kernel        1/19/2008 12:49:16 AM
sffdisk      SFF Storage Class Driv Kernel        4/27/2007 10:35:45 PM
sffp_mmc     SFF Storage Protocol D Kernel        4/27/2007 10:35:46 PM
sffp_sd      SFF Storage Protocol D Kernel        4/27/2007 10:35:44 PM
sfloppy      High-Capacity Floppy D Kernel        11/2/2006 4:51:40 AM
sisagp       SIS AGP Bus Filter     Kernel        11/2/2006 4:35:06 AM
SiSRaid2     SiSRaid2               Kernel        10/2/2006 4:09:43 PM
SiSRaid4     SiSRaid4               Kernel        7/31/2006 6:11:46 PM
Smb          Message-oriented TCP/I Kernel        4/11/2009 12:45:22 AM
spldr        Security Processor Loa Kernel        6/21/2007 8:29:17 PM
srv          srv                    File System   2/18/2011 9:03:28 AM
srv2         srv2                   File System   4/29/2011 9:25:09 AM
srvnet       srvnet                 File System   4/29/2011 9:25:08 AM
swenum       Software Bus Driver    Kernel        1/19/2008 12:49:20 AM
Symc8xx      Symc8xx                Kernel        11/11/2005 5:45:56 PM
Sym_hi       Sym_hi                 Kernel        11/11/2005 4:07:07 PM
Sym_u3       Sym_u3                 Kernel        10/20/2005 8:12:49 PM
Tcpip        TCP/IP Protocol Driver Kernel        3/29/2012 9:56:36 AM
Tcpip6       Microsoft IPv6 Protoco Kernel        3/29/2012 9:56:36 AM
tcpipreg     TCP/IP Registry Compat Kernel        12/8/2009 12:26:18 PM
TDPIPE       TDPIPE                 Kernel        1/19/2008 1:01:07 AM
TDTCP        TDTCP                  Kernel        1/19/2008 1:01:08 AM
tdx          NetIO Legacy TDI Suppo Kernel        4/11/2009 12:45:56 AM
TermDD       Terminal Device Driver Kernel        4/11/2009 12:51:14 AM
tssecsrv     Terminal Services Secu Kernel        1/19/2008 1:01:15 AM
tunmp        Microsoft Tun Miniport Kernel        1/19/2008 12:55:40 AM
tunnel       Microsoft IPv6 Tunnel  Kernel        2/18/2010 6:28:13 AM
uagp35       Microsoft AGPv3.5 Filt Kernel        11/2/2006 4:35:07 AM
udfs         udfs                   File System   4/11/2009 12:13:59 AM
uliagpkx     Uli AGP Bus Filter     Kernel        11/2/2006 4:35:08 AM
uliahci      uliahci                Kernel        9/11/2006 4:51:11 PM
UlSata       UlSata                 Kernel        9/19/2006 8:02:59 PM
ulsata2      ulsata2                Kernel        9/19/2006 8:18:47 PM
umbus        UMBus Enumerator Drive Kernel        1/19/2008 12:53:40 AM
usbccgp      Microsoft USB Generic  Kernel        1/19/2008 12:53:29 AM
usbcir       eHome Infrared Receive Kernel        11/2/2006 4:55:08 AM
usbehci      Microsoft USB 2.0 Enha Kernel        4/11/2009 12:42:52 AM
usbhub       USB2 Enabled Hub       Kernel        4/11/2009 12:43:14 AM
usbohci      Microsoft USB Open Hos Kernel        11/2/2006 4:55:05 AM
usbprint     Microsoft USB PRINTER  Kernel        11/2/2006 5:14:58 AM
USBSTOR      USB Mass Storage Drive Kernel        4/11/2009 12:42:55 AM
usbuhci      Microsoft USB Universa Kernel        1/19/2008 12:53:20 AM
vga          vga                    Kernel        11/2/2006 4:53:56 AM
VgaSave      VgaSave                Kernel        1/19/2008 12:52:06 AM
viaagp       VIA AGP Bus Filter     Kernel        11/2/2006 4:35:06 AM
ViaC7        VIA C7 Processor Drive Kernel        11/2/2006 4:30:19 AM
viaide       viaide                 Kernel        11/2/2006 4:51:36 AM
volmgr       Volume Manager Driver  Kernel        1/19/2008 12:49:51 AM
volmgrx      Dynamic Volume Manager Kernel        4/11/2009 12:39:25 AM
volsnap      Storage volumes        Kernel        4/11/2009 12:39:37 AM
vsmraid      vsmraid                Kernel        10/2/2006 2:36:20 PM
WacomPen     Wacom Serial Pen HID D Kernel        11/2/2006 4:52:52 AM
Wanarp       Remote Access IP ARP D Kernel        1/19/2008 12:56:31 AM
Wanarpv6     Remote Access IPv6 ARP Kernel        1/19/2008 12:56:31 AM
Wd           Microsoft Watchdog Tim Kernel        11/2/2006 4:54:05 AM
Wdf01000     Kernel Mode Driver Fra Kernel        1/19/2008 12:52:21 AM
winachsf     winachsf               Kernel        12/7/2006 6:04:22 PM
WmiAcpi      Microsoft Windows Mana Kernel        11/2/2006 4:35:03 AM
ws2ifsl      Winsock IFS driver     Kernel        1/19/2008 12:56:49 AM
WUDFRd       WUDFRd                 Kernel        1/19/2008 12:53:04 AM
XAudio       XAudio                 Kernel        11/28/2006 7:44:50 PM
Your BIOS could stand to be updated, too.
Code:
System Information
Time of this report: 8/23/2012, 06:16:36
       Machine name: CIA-PC
   Operating System: Windows Vista™ Home Premium (6.0, Build 6002) Service Pack 2 (6002.vistasp2_gdr.120402-0336)
           Language: English (Regional Setting: English)
System Manufacturer: Compaq-Presario
       System Model: GX617AA-ABA SR5310F
               [B]BIOS: BIOS Date: 03/04/08 20:50:19 Ver: 5.19[/B]
          Processor: Intel(R) Pentium(R) Dual  CPU  E2140  @ 1.60GHz (2 CPUs), ~1.6GHz
             Memory: 2046MB RAM
          Page File: 1195MB used, 3871MB available
        Windows Dir: C:\Windows
    DirectX Version: DirectX 11
DX Setup Parameters: Not found
     DxDiag Version: 7.00.6002.18107 32bit Unicode
DxDiag Notes
      Display Tab 1: The file nvd3dum.dll,nvwgf2um.dll,nvwgf2um.dll is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL).  You may be able to get a WHQL logo'd driver from the hardware manufacturer.
        Sound Tab 1: The file RTKVHDA.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL).  You may be able to get a WHQL logo'd driver from the hardware manufacturer.
          Input Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (retail)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
        Card name: NVIDIA GeForce 9400 GT
     Manufacturer: NVIDIA
        Chip type: GeForce 9400 GT
         DAC type: Integrated RAMDAC
       Device Key: Enum\PCI\VEN_10DE&DEV_0641&SUBSYS_0562196E&REV_A1
   Display Memory: 1777 MB
 Dedicated Memory: 1009 MB
    Shared Memory: 767 MB
     Current Mode: 1440 x 900 (32 bit) (75Hz)
          Monitor: HP w17e Wide LCD Monitor
      Driver Name: nvd3dum.dll,nvwgf2um.dll,nvwgf2um.dll
   Driver Version: 8.17.0013.0142 (English)
      DDI Version: 10
   BGRA Supported: Yes
Driver Attributes: Final Retail
 Driver Date/Size: 5/15/2012 06:26:00, 15322432 bytes
      WHQL Logo'd: No
  WHQL Date Stamp: None
Device Identifier: {D7B71E3E-4501-11CF-507A-6F251FC2C535}
        Vendor ID: 0x10DE
        Device ID: 0x0641
        SubSys ID: 0x0562196E
      Revision ID: 0x00A1
      Revision ID: 0x00A1
      Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
 Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                   {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                   {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                   {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                   {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                   {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                   {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                   {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                   {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                   {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                   {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
     DDraw Status: Enabled
       D3D Status: Enabled
       AGP Status: Enabled
Sound Devices
            Description: Speakers (Realtek High Definition Audio)
 Default Sound Playback: Yes
 Default Voice Playback: Yes
            Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_103C2A59&REV_1000
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            Driver Name: RTKVHDA.sys
         Driver Version: 6.00.0001.5789 (English)
            WHQL Logo'd: No
          Date and Size: 2/11/2009 12:38:14, 2324512 bytes
            Other Files:
        Driver Provider: Realtek Semiconductor Corp.
         HW Accel Level: Basic
              Cap Flags: 0xF1F
    Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
 Static/Strm HW 3D Bufs: 0, 0
              HW Memory: 0
       Voice Management: No
 EAX(tm) 2.0 Listen/Src: No, No
   I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
DirectInput Devices
      Device Name: Mouse
         Attached: 1
    Controller ID: n/a
Vendor/Product ID: n/a
        FF Driver: n/a
      Device Name: Keyboard
         Attached: 1
    Controller ID: n/a
        FF Driver: n/a
      Device Name: USB Keyboard
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x04D9, 0x1702
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x27CB
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 4/11/2009 00:43:16, 196096 bytes
| Driver: usbd.sys, 1/18/2008 21:53:18, 5888 bytes
Gameport Devices
PS/2 Devices
+ HID Keyboard Device
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 4/11/2009 00:38:40, 17408 bytes
| Driver: kbdclass.sys, 1/18/2008 23:41:54, 35384 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: i8042prt.sys, 1/18/2008 21:49:20, 54784 bytes
+ HID-compliant mouse
| Vendor/Product ID: 0x15D9, 0x0A4D
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouhid.sys, 1/18/2008 21:49:18, 15872 bytes
| Driver: mouclass.sys, 1/18/2008 23:41:54, 34360 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
| Driver: termdd.sys, 4/11/2009 02:32:52, 53224 bytes
| Driver: sermouse.sys, 1/18/2008 21:49:18, 19968 bytes
Disk & DVD/CD-ROM Drives
      Drive: C:
 Free Space: 156.7 GB
Total Space: 228.9 GB
File System: NTFS
      Model: Hitachi HDP725025GLA380 ATA Device
      Drive: D:
      Drive: E:
      Model: HL-DT-ST DVD-RAM GH10L ATA Device
     Driver: c:\windows\system32\drivers\cdrom.sys, 6.00.6002.18005 (English), 4/11/2009 00:39:17, 67072 bytes
System Devices
     Name: Intel(R) 82801G (ICH7 Family) Ultra ATA Storage Controllers - 27DF
Device ID: PCI\VEN_8086&DEV_27DF&SUBSYS_2A59103C&REV_01\3&11583659&0&F9
   Driver: C:\Windows\system32\DRIVERS\intelide.sys, 6.00.6001.18000 (English), 1/18/2008 23:41:22, 17976 bytes
   Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.00.6002.18005 (English), 4/11/2009 02:32:52, 43496 bytes
   Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.00.6002.18005 (English), 4/11/2009 02:32:26, 19944 bytes
   Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.00.6002.18005 (English), 4/11/2009 02:32:42, 109032 bytes
     Name: Intel(R) 82801G (ICH7 Family) SMBus Controller - 27DA
Device ID: PCI\VEN_8086&DEV_27DA&SUBSYS_2A59103C&REV_01\3&11583659&0&FB
   Driver: n/a
     Name: High Definition Audio Controller
Device ID: PCI\VEN_8086&DEV_27D8&SUBSYS_2A59103C&REV_01\3&11583659&0&D8
   Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.00.6002.18005 (English), 4/11/2009 00:42:42, 561152 bytes
     Name: Intel(R) 82801G (ICH7 Family) PCI Express Root Port - 27D2
Device ID: PCI\VEN_8086&DEV_27D2&SUBSYS_2A59103C&REV_01\3&11583659&0&E1
   Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.00.6002.18005 (English), 4/11/2009 02:32:55, 149480 bytes
     Name: Intel(R) 82801G (ICH7 Family) PCI Express Root Port - 27D0
Device ID: PCI\VEN_8086&DEV_27D0&SUBSYS_2A59103C&REV_01\3&11583659&0&E0
     Name: Intel(R) 82801G (ICH7 Family) USB2 Enhanced Host Controller - 27CC
Device ID: PCI\VEN_8086&DEV_27CC&SUBSYS_2A59103C&REV_01\3&11583659&0&EF
   Driver: C:\Windows\system32\drivers\usbehci.sys, 6.00.6002.18005 (English), 4/11/2009 00:42:52, 39936 bytes
   Driver: C:\Windows\system32\drivers\usbport.sys, 6.00.6002.18005 (English), 4/11/2009 00:42:57, 226304 bytes
   Driver: C:\Windows\system32\drivers\usbhub.sys, 6.00.6002.18005 (English), 4/11/2009 00:43:16, 196096 bytes
   Driver: C:\Windows\system32\hccoin.dll, 6.00.6000.16386 (English), 11/2/2006 01:46:06, 8704 bytes
   Driver: C:\Windows\system32\hcrstco.dll, 6.00.6001.18000 (English), 1/18/2008 23:34:26, 15872 bytes
     Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CB
Device ID: PCI\VEN_8086&DEV_27CB&SUBSYS_2A59103C&REV_01\3&11583659&0&EB
   Driver: C:\Windows\system32\drivers\usbuhci.sys, 6.00.6001.18000 (English), 1/18/2008 21:53:22, 23552 bytes
     Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CA
Device ID: PCI\VEN_8086&DEV_27CA&SUBSYS_2A59103C&REV_01\3&11583659&0&EA
     Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C9
Device ID: PCI\VEN_8086&DEV_27C9&SUBSYS_2A59103C&REV_01\3&11583659&0&E9
     Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C8
Device ID: PCI\VEN_8086&DEV_27C8&SUBSYS_2A59103C&REV_01\3&11583659&0&E8
     Name: Intel(R) 82801GB/GR/GH (ICH7 Family) Serial ATA Storage Controller - 27C0
Device ID: PCI\VEN_8086&DEV_27C0&SUBSYS_2A59103C&REV_01\3&11583659&0&FA
     Name: Intel(R) 82801GB/GR (ICH7 Family) LPC Interface Controller - 27B8
Device ID: PCI\VEN_8086&DEV_27B8&SUBSYS_2A59103C&REV_01\3&11583659&0&F8
   Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.00.6001.18000 (English), 1/18/2008 23:41:16, 16440 bytes
     Name: Intel(R) 945G/GZ/P/PL PCI Express Root Port - 2771
Device ID: PCI\VEN_8086&DEV_2771&SUBSYS_00008086&REV_02\3&11583659&0&08
     Name: Intel(R) 945G/GZ/P/PL Processor to I/O Controller - 2770
Device ID: PCI\VEN_8086&DEV_2770&SUBSYS_2A59103C&REV_02\3&11583659&0&00
   Driver: n/a
     Name: Intel(R) 82801 PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_2A59103C&REV_E1\3&11583659&0&F0
     Name: Realtek RTL8101E Family PCI-E Fast Ethernet NIC (NDIS 6.0)
Device ID: PCI\VEN_10EC&DEV_8136&SUBSYS_2A59103C&REV_01\4&1ADB76D9&0&00E1
   Driver: C:\Windows\system32\DRIVERS\Rtlh86.sys, 6.196.0803.2007 (English), 8/3/2007 06:44:00, 91648 bytes
     Name: NVIDIA GeForce 9400 GT
Device ID: PCI\VEN_10DE&DEV_0641&SUBSYS_0562196E&REV_A1\4&1F1B1882&0&0008
   Driver: C:\Program Files\NVIDIA Corporation\Drs\dbInstaller.exe, 8.17.0013.0142 (English), 5/15/2012 06:26:00, 199488 bytes
   Driver: C:\Program Files\NVIDIA Corporation\Drs\nvdrsdb.bin, 5/15/2012 06:26:00, 1066872 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\nv_disp.inf_2f82bdf9\NvCplSetupEng.exe, 1.00.0001.0000 (English), 5/15/2012 06:26:00, 28418392 bytes
   Driver: C:\Program Files\NVIDIA Corporation\license.txt, 5/15/2012 06:26:00, 21887 bytes
   Driver: C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL.dll, 1.00.0000.0000 (English), 5/15/2012 06:26:00, 61248 bytes
   Driver: C:\Windows\system32\DRIVERS\nvlddmkm.sys, 8.17.0013.0142 (English), 5/15/2012 06:26:00, 11354944 bytes
   Driver: C:\Windows\system32\nvapi.dll, 8.17.0013.0142 (English), 5/15/2012 06:26:00, 2368832 bytes
   Driver: C:\Windows\system32\nvcompiler.dll, 8.17.0013.0142 (English), 5/15/2012 06:26:00, 17551680 bytes
   Driver: C:\Windows\system32\nvcuda.dll, 8.17.0013.0142 (English), 5/15/2012 06:26:00, 5982528 bytes
   Driver: C:\Windows\system32\nvcuvenc.dll, 8.17.0013.0142 (English), 5/15/2012 06:26:00, 2445120 bytes
   Driver: C:\Windows\system32\nvcuvid.dll, 8.17.0013.0142 (English), 5/15/2012 06:26:00, 2524992 bytes
   Driver: C:\Windows\system32\nvd3dum.dll, 8.17.0013.0142 (English), 5/15/2012 06:26:00, 15322432 bytes
   Driver: C:\Windows\system32\nvinfo.pb, 5/15/2012 06:26:00, 11190 bytes
   Driver: C:\Windows\system32\nvoglv32.dll, 8.17.0013.0142 (English), 5/15/2012 06:26:00, 19607872 bytes
   Driver: C:\Windows\system32\nvwgf2um.dll, 8.17.0013.0142 (English), 5/15/2012 06:26:00, 8105280 bytes
   Driver: C:\Windows\system32\nvdispco32.dll, 2.00.0025.0002 (English), 5/15/2012 06:26:00, 1000768 bytes
   Driver: C:\Windows\system32\nvgenco32.dll, 2.00.0014.0002 (English), 5/15/2012 06:26:00, 883008 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
MP3 Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00600800,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
Full Screen Renderer,0x00200000,1,0,,6.06.6002.18533
WMT VIH2 Fix,0x00200000,1,1,WLXVAFilt.dll,15.04.3502.0922
Record Queue,0x00200000,1,1,WLXVAFilt.dll,15.04.3502.0922
WMT Switch Filter,0x00200000,1,1,WLXVAFilt.dll,15.04.3502.0922
WMT Virtual Renderer,0x00200000,1,0,WLXVAFilt.dll,15.04.3502.0922
WMT DV Extract,0x00200000,1,1,WLXVAFilt.dll,15.04.3502.0922
WMT Virtual Source,0x00200000,0,1,WLXVAFilt.dll,15.04.3502.0922
WMT Sample Information Filter,0x00200000,1,1,WLXVAFilt.dll,15.04.3502.0922
Multiple File Output,0x00200000,2,2,WMM2FILT.dll,
WMT Black Frame Generator,0x00200000,1,1,WMM2FILT.dll,
WMT Import Filter,0x00200000,0,1,WMM2FILT.dll,
DV Muxer,0x00400000,0,0,,6.06.6001.18000
Color Space Converter,0x00400001,1,1,,6.06.6002.18533
WMT Interlacer,0x00200000,1,1,WMM2FILT.dll,
WM ASF Reader,0x00400000,0,0,,11.00.6001.7000
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.6001.7000
AVI Splitter,0x00600000,1,1,,6.06.6002.18533
VGA 16 Color Ditherer,0x00400000,1,1,,6.06.6002.18533
Microsoft MPEG-2 Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,11.00.6001.7110
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.6002.18363
WMT Format Conversion,0x00200000,1,1,WMM2FILT.dll,
9x8Resize,0x00200000,1,1,WMM2FILT.dll,
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.6002.18363
WMT Virtual Source,0x00200000,0,1,WMM2FILT.dll,
Microsoft TV Caption Decoder,0x00200001,1,0,MSTVCapn.dll,6.00.6002.18536
MJPEG Decompressor,0x00600000,1,1,,6.06.6002.18533
CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.00.6002.18242
MPEG-I Stream Splitter,0x00600000,1,2,,6.06.6002.18533
SAMI (CC) Parser,0x00400000,1,1,,6.06.6002.18533
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.6001.18000
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.6002.18363
WMT AudioAnalyzer,0x00200000,1,1,WMM2FILT.dll,
Microsoft MPEG-2 Video Encoder,0x00200000,2,0,msmpeg2enc.dll,11.00.6001.7000
Stretch Video,0x00200000,1,1,WMM2FILT.dll,
Internal Script Command Renderer,0x00800001,1,0,,6.06.6002.18533
MPEG Audio Decoder,0x03680001,1,1,,6.06.6002.18533
DV Splitter,0x00600000,1,2,,6.06.6001.18000
Video Mixing Renderer 9,0x00200000,1,0,,6.06.6002.18533
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,11.00.6001.7000
Frame Eater,0x00200000,1,1,WMM2FILT.dll,
Allocator Fix,0x00200000,1,1,WMM2FILT.dll,
ACM Wrapper,0x00600000,1,1,,6.06.6002.18533
Video Renderer,0x00800001,1,0,,6.06.6002.18533
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.6002.18363
Capture ASF Writer,0x00200000,0,0,WMM2FILT.dll,
Line 21 Decoder,0x00600000,1,1,,6.06.6002.18533
Video Port Manager,0x00600000,2,1,,6.06.6002.18533
Video Renderer,0x00400000,1,0,,6.06.6002.18533
Bitmap Generate,0x00200000,1,1,WMM2FILT.dll,
Proxy Sink,0x00200000,1,0,WMM2FILT.dll,
File Writer,0x00200000,1,0,WLXVAFilt.dll,15.04.3502.0922
Proxy Source,0x00200000,0,1,WMM2FILT.dll,
WM ASF Writer,0x00400000,0,0,,11.00.6001.7000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.00.6001.18000
WMT Sample Information Filter,0x00200000,1,1,WMM2FILT.dll,
File writer,0x00200000,1,0,,6.06.6001.18000
DVD Navigator,0x00200000,0,3,,6.06.6002.18533
WMT DV Extract,0x00200000,1,1,WMM2FILT.dll,
Overlay Mixer2,0x00200000,1,1,,6.06.6002.18533
AVI Draw,0x00600064,9,1,,6.06.6002.18533
Microsoft MPEG-2 Audio Encoder,0x00200000,2,0,msmpeg2enc.dll,11.00.6001.7000
WST Pager,0x00800000,1,1,WSTPager.ax,6.06.6001.18000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.6002.18363
Record Queue,0x00200000,1,1,WMM2FILT.dll,
DV Video Decoder,0x00800000,1,1,,6.06.6001.18000
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.6002.18005
Null Renderer,0x00200000,1,0,qedit.dll,6.06.6002.18005
WMT Log Filter,0x00200000,1,1,WMM2FILT.dll,
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.6002.18496
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,11.00.6001.7000
WMT Virtual Renderer,0x00200000,1,0,WMM2FILT.dll,
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.6002.18363
Smart Tee,0x00200000,1,2,,6.06.6001.18000
Overlay Mixer,0x00200000,0,0,,6.06.6002.18533
AVI Decompressor,0x00600000,1,1,,6.06.6002.18533
WMT MuxDeMux Filter,0x00200000,0,0,WMM2FILT.dll,
NetBridge,0x00200000,2,0,netbridge.dll,6.01.6001.18000
AVI/WAV File Source,0x00400000,0,2,,6.06.6002.18533
WMT Volume,0x00200000,1,1,WMM2FILT.dll,
Wave Parser,0x00400000,1,1,,6.06.6002.18533
MIDI Parser,0x00400000,1,1,,6.06.6002.18533
Multi-file Parser,0x00400000,1,1,,6.06.6002.18533
File stream renderer,0x00400000,1,1,,6.06.6002.18533
WMT VIH2 Fix,0x00200000,1,1,WMM2FILT.dll,
Microsoft MPEG-1/DD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,11.00.6001.7000
AVI Mux,0x00200000,1,0,,6.06.6001.18000
Line 21 Decoder 2,0x00600002,1,1,,6.06.6002.18533
File Source (Async.),0x00400000,0,1,,6.06.6002.18533
File Source (URL),0x00400000,0,1,,6.06.6002.18533
Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.6002.18005
AudioRecorder WAV Dest,0x00200000,0,0,,6.00.6001.18000
AudioRecorder Wave Form,0x00200000,0,0,,6.00.6001.18000
SoundRecorder Null Renderer,0x00200000,0,0,,6.00.6001.18000
Infinite Pin Tee Filter,0x00200000,1,1,,6.06.6001.18000
WMT Switch Filter,0x00200000,1,1,WMM2FILT.dll,
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.00.6002.18005
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,WMM2FILT.dll,
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.6002.18496
MPEG Video Decoder,0x40000001,1,1,,6.06.6002.18533
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,,6.00.6001.18000
WDM Streaming Data Transforms:
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,6.00.6001.18000
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,,6.06.6001.18000
MJPEG Compressor,0x00200000,0,0,,6.06.6002.18533
Cinepak Codec by Radius,0x00200000,1,1,,6.06.6001.18000
Intel IYUV codec,0x00200000,1,1,,6.06.6001.18000
Microsoft RLE,0x00200000,1,1,,6.06.6001.18000
Microsoft Video 1,0x00200000,1,1,,6.06.6001.18000
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IMA ADPCM,0x00200000,1,1,,6.06.6002.18533
Microsoft ADPCM,0x00200000,1,1,,6.06.6002.18533
GSM 6.10,0x00200000,1,1,,6.06.6002.18533
CCITT A-Law,0x00200000,1,1,,6.06.6002.18533
CCITT u-Law,0x00200000,1,1,,6.06.6002.18533
MPEG Layer-3,0x00200000,1,1,,6.06.6002.18533
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,,6.06.6002.18533
Microsoft GS Wavetable Synth,0x00200000,1,0,,6.06.6002.18533
WDM Streaming Capture Devices:
,0x00000000,0,0,,
,0x00000000,0,0,,
,0x00000000,0,0,,
WDM Streaming Rendering Devices:
Realtek HD Audio rear output,0x00200000,1,1,,6.00.6001.18000
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6002.18496
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6002.18496
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6002.18496
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6002.18496
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.6002.18005
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.6002.18496
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.6002.18496
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,EncDec.dll,6.06.6002.18528
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.6002.18528
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.6002.18528
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (Realtek High Definiti,0x00200000,1,0,,6.06.6002.18533
Default DirectSound Device,0x00800000,1,0,,6.06.6002.18533
Default WaveOut Device,0x00200000,1,0,,6.06.6002.18533
DirectSound: Speakers (Realtek High Definition Audio),0x00200000,1,0,,6.06.6002.18533
EDIT: Just realized that you just reinstalled. The drivers will update in time if your windows updater is set properly.
