ShadowStorage keeps changing it's own size.
AndyTampa
Is there a way to see which program keeps changing the ShadowStorage Maxsize to unbounded?
It keeps filling up my hard drive and I have to reset it, but then it resets itself to unbounded. It was using 450 GB and I just lowered it to 100GB even though that's probably a little overkill. That particular drive is 600GB.
Is there any way to figure out which program is doing this so I can stop it?
Does something about Vista trigger this automatic reset?
    Windows Vista Home Premium SP2, 32-bit
    Retrofitted Refurbished Gateway
    AMD
    ASUS M3A78-EM
    Acer 22-in Flat Screen Monitor
    Logitech M705 Wireless Mouse
    Logitech K350 Wireless Keyboard
AndyTampa
Well, nobody answered. It happened again, so I'll ask again. VSSADMIN keeps changing its size to UNBOUNDED. Is there an event log I can look up or something to see when this setting is getting changed and by which program?
    AMD
    ASUS M3A78-EM
ilikefree
Are you setting it in CMD run as administrator with this command
vssadmin Resize ShadowStorage /For=C: /On=C: /Maxsize=100GB
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
AndyTampa
Yes, and after some time I get a notice that my Hard Drive is almost full. Then I check and it's set to UNBOUNDED again.
Is there a log somewhere to see when it changes or what changed it?
    AMD
    ASUS M3A78-EM
AndyTampa
It's been over a year and I haven't had this problem resolved yet. Is there an event logged somewhere each time the VSS is changed? Is there a program that I can use to capture such changes to the VSS?
I'm trying to determine which program is making the changes.
    AMD
    ASUS M3A78-EM
wither 3
Is it possible that you have Vista set to periodically create a system restore point? That will affect VSS.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
AndyTampa
The last restore point is from 7/24/18 when Kaspersky updated itself. At some point, the VSSADMIN reset itself back to UNBOUNDED again when I had set it to 50GB. Currently, it's using less than 25GB. It shouldn't matter if it's doing periodic restore points anyway. It should delete the oldest instead of making itself limitless.
I do have Acronis True Image doing backups. I've often wondered if Acronis is doing it, but I can't find anything online stating so.
I'm looking for a way to see when it's happening or what is causing/requesting it to happen.
    AMD
    ASUS M3A78-EM
wither 3
Windows doesn't delete restore points. In fact, the folder where they're stored (have to look up where that is) can get so large that it can really slow down a system.
I don't think imaging a drive would affect VSS but, that's just my opinion.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
townsbg
~~тσωηsвg~~
Windows does delete restore points.
    Windows 7 Pro x64
    Mid 2010 iMac
    Quad core 3.2 Ghz Intel I3
    8 gb
    ATI Radeon HD 5670 512 mb ram
    1920x1080 and 1440x900
    1 TB
    N/A
    Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1440 x 900
    1 TB & 360 GB
wither 3
Thank you for that. My apologies. Need to be more careful. I see that one needs 300 MB of free space on each drive that's being protected and when it reaches that point, older ones are deleted.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
AndyTampa
Apparently not on my machine. It just makes more room.
My question remains, and nobody has actually said yes or no, but is there a program or utility that will let me monitor or see when the shadowstorage limit changes and what prompts the change?
    AMD
    ASUS M3A78-EM
wither 3
If you run this command from the command prompt as administrator-
vssadmin list shadows
the "Provider" in each instance listed is supposed to tell you what program is using the shadow storage. I ran it and, in every instance, the program is Microsoft Software Shadow Copy Provider Service 1.0. Since the date and time that each instance is created is shown, that should answer your question about when it is changing. Trouble is, it really doesn't tell you what program changed it. I wonder if this, from Microsoft, might help with that question-
Vssadmin List Writers Lists shadow copy writers, which support communicating with the Volume Shadow Copy service to ensure that files are captured in a consistent state. By default, subscribed writers include an operating system writer, a registry writer, a WMI writer, and a search service writer, among others. SQL Server also provides a Volume Shadow Copy writer.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
AndyTampa
I get the same thing you do and a list of writers didn't provide anything useful either. While the list of shadows and their creation dates is interesting, it doesn't tell me what changed the storage size. I keep changing it to 100GB, which is more than enough room, but something keeps changing it back to "UNBOUNDED".
Code:
C:\Windows\system32>vssadmin list shadowstorage
vssadmin 1.1 - Volume Shadow Copy Service administrative command-line tool
(C) Copyright 2001-2005 Microsoft Corp.
Shadow Copy Storage association
   For volume: (C:)\\?\Volume{68d47df8-92e3-11dc-845d-806e6f6e6963}\
   Shadow Copy Storage volume: (C:)\\?\Volume{68d47df8-92e3-11dc-845d-806e6f6e69
63}\
   Used Shadow Copy Storage space: 404.674 GB
   Allocated Shadow Copy Storage space: 407.589 GB
   Maximum Shadow Copy Storage space: UNBOUNDED
    AMD
    ASUS M3A78-EM
AndyTampa
On a hunch, I searched for Acronis True Image VSS unbounded and found a reference in the Acronis forum that mentions the same symptom, so I may be on my way to discovering how to fix it. Unfortunately, they keep talking about going to option settings I can't find yet. That may or may not be because I'm on Vista. The site isn't specific on windows versions because it's all about Acronis.
    AMD
    ASUS M3A78-EM
wither 3
Are you using Acronis to do backups? If so, does either going to the snapshot method (as suggested in the Acronis forum) or disabling Acronis stop the problem?
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
wither 3
Any progress?
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
AndyTampa
I know that I posted in an Acronis Forum, but haven't seen a response yet. I'll look again soon.
    AMD
    ASUS M3A78-EM
